Root [UNOFFICIAL] 5.0.2 SlimLP Alpha DEPRECATED!
  • Thread starter Thread starter Member1771050
  • Start date Start date
  • Tags Tags
    lg l70
And one cool info:
If you install internal memory disabler, "move to SD" button in app options is available :)
Together with my guide for enabling non-movable apps to be moved, we can have a lot of free memory system memory :)
Managed to download it attempted to install and somewhere something probably didnt go right and it got stuck waited an hour for it to do something but it stayed on that one part. Was I supposed to factory reset? I'm on the ms323
*Sarcastic Facepalm* You're ALWAYS supposed to factory reset after you install a rom. It's been like that since the beginning of custom roms ;)
@zlaja84 Can you implement net.sh script into this rom, so it can be used just by turning data ON?It shouldn't be too hard if you know where you should place it in code,and how to make it triggered by turning ON mobile data...It doesn't matter if it's buggy, i just don't like doing it manualy.... :)
I won't do that, it's way too dirty of a hack. Data is a known problem on various devices, not only L70. And they have same solution as we do. There's a flashable zip circulating here which should ease the process though :)
Where? :D
Edit: I just flashed SlimLP,but i can't get disabler to work,i have done in this order:
1.In CWM Factory reset and format /system
2.Flash SlimLP
3.Flash gapps
4.Flash SuperSu
5.Wipe /data and /media
6.Flash disabler
7.Reboot
Have i done something wrong?
Where? :D
2.Flash SlimLP
3.Flash gapps
4.Flash SuperSu
6.Flash disabler
7.Reboot
I flashed disabler after flashing rom and before everything else. You must wait for about 10 mins because off gapps, it takes time to load rom and gapps for first time.
My mistake, it's working fine... :D
A funny thing is that mobile data looks like it's working, but it doesn't work.. :)
Probably would be a dysfunctional button most of the time because you have to run the script a couple of times if you switch from WiFi to mobile data a lot...I personally think smanager is the best bet for the script for right now.
