Power went down where I live, as soon as it gets back, I'm off to building@zlaja84 When can we expect new build with fixed data?![]()
Keep fiddling with it back in and out to your contacts show idk why it does that even on stock it doesguys i cant see my contacts from my sim card , how to fix that ?
20150309:
- Fixed RIL (d325) and data, thanks vm03
- possible fix for d325 systemui fc
No. I would have stated in changelog if it was fixed.rear câmera is working for the D325F8 device?
I will give my best to publish it is as soon as possible :/@zlaja84 Can we expect disabler any time soon?
Hm... I have never experienced that on any rom, not even stockThis rom is very fast and battery friendly, but needs to work around stability. Internet, Facebook and other apps that eats more ram crashes.
but we all have different usage habbits.It's called Slim for a reasonNo file manager?
Also, no music player (if you don't install gapps), and so on. You install what you like
Nice rom runnig cool way better than stock , but can i ask some dumb questions ?
1 Can i change the theme ?
2 How to set the downloads to download to sd card ?
3 how can i make my just taken photos save directly on my sd
4 how to enable knock wakeup or knock code
5 vibrate back button
6 vibrate pressing letters on keyboard when tipeing
I know its stock but i had to ask
Sorry for beeing noob
Has any user with d325 tested this rom?
Thanks for testingyess! Working Perfectly but it looks bad!
looks tiny.LOL
No forcecloses!
tnx man!
Could you or someone possibly provide me with framework-res.apk from this ROM?@zlaja84 Any news about disabler,i'm just wait for that to flash new build with fixed data?![]()
On my D325 key vibration work. On keyboard settings can change vibration long.6. That, for some reason, doesn't work on any custom rom for L70.
Huh? For me it doesn't work... Or maybe I just turned it off?On my D325 key vibration work. On keyboard settings can change vibration long.
I could...but i still use old build....why do you need someone else to provide it,when you have it also?Could you or someone possibly provide me with framework-res.apk from this ROM?
Because I'm currently testing PAC LP, and I'm too lazy to flash againI could...but i still use old build....why do you need someone else to provide it,when you have it also?![]()
I just set up pac the way I wanted
