Root Unofficial CyanogenMod 11 for LG L70 D320 D320n D325
How best to make the SD card in CM11:
  • Total voters
    110
  • Poll closed .
I found new bug. With active double touch to wake cpu isn`t go to deep sleep.
This, and bugs you reported a few posts back, are most probably caused by using ramdisk in kernel from previous build (that patch for inernal memory you made, I'm reffering to that).
@zlaja84
I flash cm-11-20150110 without my ramdisk and framework changes, because in cm-11-20150118 accelometer isn`t work(in 20150110 work well). In cm-11-20150118 with my changes I had same bug.
I think it's not bug because as i stated few post before the screen using high amount of battery energy and i found it's happened also on the stock rom when the knock on mode enable. The conclusion is, the screen has to still on so it could detect the tap/knock to wake up the phone.
And back to my usual : turn off the tap to wake up on cm11 as i did on the stock rom to save battery. :)
Hi vm03 or anyone who can advise. I know im out of topic here but just want your expert advice on compiling your kernel if i can do it in Ubuntu14.04 LTS 32bit? I see some forum threads that it needs to be 64bit to compile? Thank you.
For build only kernel can use 32bit.
