Root Unofficial CyanogenMod 11 for LG L70 D320 D320n D325
How best to make the SD card in CM11:
  • Total voters
    110
  • Poll closed .
How I know, it is some kind of log that is happening in the phone, not system... Logcat shows like connecting to wifi, installing app while dmesg shows something like "1 finger pressed at x,y, 1 finger released at... It is how I know...
you know any way to make the rear camera D325 working again?
Hallo,
i have rooted and ulocked my phone. Now i want to install cm11. I am not sure if i must have to wipe system too or ist this then a problem?
1. Install stok rom and root it.
2. Install Terminal emulator
3. Reboot phone
4. Open and close camera
5. Open Terminal and on it
Code:
su
dmesg > /sdcard/dmesg.txt
cat /proc/cmdline > /sdcard/cmdline.txt
getprop > /sdcard/prop.txt
6. Send files dmesg.txt cmdline.txt prop.txt to me.
3. Reboot phone
Code:
su
I can install the backup ROM Stock I have?
@vm03 or anyone please help :)
I have tried .config and device tree modding for cameras imx111 and imx119 for my D325f8 device.
Upon compiling, it stops without error but no zimage in my boot folder. Here where it stops compliling:
CC drivers/staging/prima/CORE/WDI/WPAL/src/wlan_qct_pal_trace.o
LD drivers/staging/prima/wlan.o
LD drivers/staging/prima/built-in.o
LD drivers/staging/built-in.o
LD drivers/built-in.o
fishbowlFX@ubuntu14:~/android/kernel/sealw5ds$
@@@@@@@@@@@@@@@@@@EDIT@@@@@@@@@@@@@@@@@@@@@@@
Thanks vm03 for insight. I got the usual compilation workaround of folder or directory not found error.
Error may be many strings above.
How you compile kernel?
Good people.
I delete my irrelevant post. This is not development thread. I will post once kernel compilation completed and working. My apologies.
sorry if my question might bother'm trying to help a fellow who has this 320f8 I have a D320N and everything works fine, but me and read the 14 pages of thread and could not find the solution if someone could explain politely thanks
*sorry for my English also use google translator perhaps not help much to tarducir thread and why not the solution thanks to all
You alone are not the problem, problem is that questions like that are asked on every page...
