ledosladoledi
I did it by making a PART, not WHOLE sdcard ext4 and then I used some scypts in .zip that copy whole system to SD and then runs it from there... Complicated... But after this speed of my phone dropped because its reading everything from sd so you want to rethink about that...Well, if you recall - the internalSD was removed. I thought that to get it working - you had to format your externalSD with an ext4 partition.... Or am I on something?
. I would just like a mod to remove / emulated / legacy /0
. I tried to change something in the boot.img more only had bootloop
! Thanks
. Any way to mount / card data with two FAT32 partitions and another ext4? want to ride the entire partition / data to ext4 Card!
