Root Unofficial CyanogenMod 12.1 for LG L70 D320 D320n D325 MS323
I use internal disabler for cm 12.1 06052015 when i tried install mortal kombat x it said insufficient space, is internal disabler doesn't change the play store download location?
They apps are ok after reboot just shortcuts missing but if you drain battery and phobe turnoff itself apps in sd card are uniatalled
Shortcuts disappear because sd card apps are loaded after internal memory-apps.
This makes the launcher think that those apps are gone.
After all apps are loaded, they will appear in the appdrawer only.
I have not experienced problems with apps uninstalling.
My phone died 2 times because of low battery, but when i powered on, the sd card apps where still there.
After CM updates, it takes longer to load the sd card apps. About 5mins. But they are still there. My apps are not uninstalled.
I think that the ”internal diabler” only disables EMULATED internal storage. This means photos, music and downloaded files will go on the sd card.
BUT
Apps will be installed in the internal memory. You can move apps to sd card from ”Settings/Apps”
Mby i should wait longer, i falshed twrp and istalled latest rom 08 buttons works, 2 hrs tunein radio and check fb twitter instagram skype chatting 88% battery, not sure cos of newest update or twrp but buttery is great again and work colder just like stock 4.4.2.
Great work @vm03
As you say in beginning, also in stok it decrease brightness if temp is height. If you have ghost in screen on cold phone, i think you have hardware problem.
What mesurments of temp where the logcat from? Cpu? Becuse it still gets warm. Wen it feels cold, theres no ghosting, could the battery be producing the heat?
Great work @vm03
Its the latest update that matters, battery use is really great, 0% discharged in 7 hours, I left my phone to sleep. And I use PHILZ rec
But, latest update broke the KEY 249 CHANNEL_UP
I usually can remap it to APP_SWITCH, and now I can't remap it anymore
It doesn't even give touch feedback (vibrate)
Please fix, thanks
Using D325 (dual sim)
Please fix, thanks
Use TWRP, this can fix your problem i think.
Ok so if it is a hardware problem will simply flashibg a kdz make it ok to claim under warrenty? Also some idiot sent 40volts into my headphone jack about half a year ago and headphones do not work anymour so if they see that will they refuse to help even though its a completely unrelated problem?
Build 2015-05-08 fix keys on a d320f8 :) thanks a lot @vm03 , i think you should add to the tittle this model except for the rear camera everything works perfectly :)
The laf partition was backed up when you unlocked the bootloader.
It should be backed up in the booloader unlocking folder.
If you cannot find your laf.img, then i will upload my D320N laf.img.
I can't access my backup of the LAF.img, so can you upload yours?
Thanks for all the hard work on the CM12.1 ROM and helping people!!!
Extract the archive first.
(This file will be available only 24 hours starting now)
-file deleted-
Hello , I have problem I installed latest version of cm and nameles rom's. But my home button do not work, on the other hand menu button acts like home. I did full clean install
Make sure that you're using Twrp recovery and/or corect aboot.bin.
