Root Unofficial CyanogenMod 12.1 for LG L70 D320 D320n D325 MS323
Hi. I just flash my LG L70 D320AR (i'm from Argentina) and my rear camera doesn't work, any sugestion?
And...someone can tell me how can i install apps in my SD card? because link2sd is detecting internal memory as SD card
Tanks
Is this the fastboot screen? And if so I can't for the life of me get my PC to recognize it I keep getting errors using minimal adb & fastboot...any suggestions
No, that is the download mode.
Hi. I have just flashed on my LG L70 D320AR (I'm from Argentina) and my rear camera doesn't work. Any suggestion?
And...Can someone tell me how can I install apps in my SD card? Because link2sd is detecting internal memory as SD card.
Thanks
Hi!
Firstly, make sure that you are using TWRP recovery.
To move apps to sd card, go to settings, apps, press menu button and choose default location for installing apps. After that, you will be able to move almost any app to sd card.
Hey there I installed this rom on my lg ms323 but after installation I facing this problem.when I tried to access to security section of settings that time it showed this massage unfortunately settings has stopped.and for this problem I cant install any app.
Note:I didn't install gapp
I m using lg l70 D325.CM12.1.1 Build-2015-05-07 works great for me, so far I have found no problem except a very little bug,
The User profile is not customizable, when I tap that it says Contact doesn't exist. I m giving a screenshot.....
I have updated build -2015-05-13 but haven't seen any changes ....... Otherwise it works really great for me. Thank you for this greate ROM ....... I will grateful if u fix this bug...... Thank you once again......
I have updated build -2015-05-13 but haven't seen any changes ....... Otherwise it works really great for me. Thank you for this greate ROM ....... I will grateful if u fix this bug...... Thank you once again......View attachment 87382
Have you tried editing the contact crom the contacts app?
unable to boot past lg screen and im rooted
To boot to fastboot you have to disable download mode. That means zeroing the laf partition. There's a tutorial on the "Lg L70 - Root" forum.
yay thanks i was able to fix my bootloop issue
it turns out that i had to hold the key combo for recovery longer
but now im all booted up and im having fc problems (not on lockscreen)
its usually a "google play services" fc and then the app itself
is anyone having this issue or can offer some help
greatly appreciated :)
Go to contacts -> All contacts and to "set up my profile."
Will the update to fix the camera in d325 saira soon?They are not the same msm323 the camera terminals pro d325? I thought that with the discovery of it would be easier to fix other devices.
ok so i believe the problem that i am facing resides in the google play services app. the version that is installed worked fine but after it updates to version 7.3.29 (1866531-430). if someone on the latest build can tell me the version you have that would be awesome. i have the ms323 BTW
