Thats really interesting. I thought it was just me. Actuallyive noticed burn will still happen on lower brightness but simply cannot be seen as the backlight isnt bright enought to show it. Its a side effect if any custom rom on this phone im pritty sure, wich for me is a shame, but even with the burn i get witch is pritty bad, i still wont want to go back to stock@Tweakforce_LG I actually had the same problem this morning what i did was lower the brightness and downloaded burn in cleaner it solved the problem for me
Hi!
Firstly, make sure that you are using TWRP recovery.
To move apps to sd card, go to settings, apps, press menu button and choose default location for installing apps. After that, you will be able to move almost any app to sd card.
You can send one d325f8 device to vm03 for fix your camera. Without device vm03 can nothing... Maybe he can, but there're so little chance...Please fix the rear cam in D320f8 Please please!!!![]()
Awesome ROM. ThanksCyanogenmod 12.1 for LG L70 D320 D320n D325 MS323
My port of CyanogenMod 12.1 for LG l70 D320 D320n D325. It is unofficial and unsupported by the CyanogenMod team.
View attachment 85068 View attachment 85069 View attachment 85070 View attachment 85071
View attachment 85072 View attachment 85073 View attachment 85074 View attachment 85075
Absolutely NO WARRANTY! You can brick and destroy you device!
For advanced users only. Please, no stupid questions.
For install need unlocked bootloader and TWRP (20140403 or later) recovery.
For correct working RIL (Sim detection) and keys you need correct (for you variant of L70) bootloader (aboot.bin).
Working:
Not working:
- Display
- touchscreen and multituch
- Hardware 3D rendring
- RIL - SMS, MMS, calls...
- Mobile data
- WiFi
- GPS
- Bluetooth
- WiFi, Bluetooth, USB tethering
- Audio - speaker, headphone, mic, routing, voip calls, etc
- Camera - photo and video
- SD card
- FM radio
- Hardware video decoding and encoding
- Sensors
- Double tap to wake
- SmartCover
- NFC for D320n?
Download
- Hardware keystore on ms323
- Rear camera for D325f8
- Any others for unknown for me versions and revisions.
See new builds on http://vasy.ru/CyanogenModOTA/builds/full/
(w5 for L70, w3ds for L40) or use OTA.
cm-12.1-20150416-UNOFFICIAL-w5.zip
cm-12.1-20150411-UNOFFICIAL-w5.zip
cm-12.1-20150403-UNOFFICIAL-w5.zip https://yadi.sk/d/ee6HEuplfiuf4
Gapps (i recommend nano) http://forum.xda-developers.com/android/software/reborn-gapps-5-t3074660
TWRP v2.8.6.0 twrp_w5_20150403.img
Source
Kernel https://github.com/vm03/android_kernel_lge_msm8610
Device https://github.com/vm03/android_device_lge_w5
https://github.com/vm03/android_device_lge_msm8610-common
Proprietary https://github.com/vm03/proprietary_vendor_lge_msm8610
- Copy zip's to SD
- Enter to recovery
- wipe data
- install zip from external_sd cm-12.<...>.zip
- install zip from external_sd gapps
- reboot
Donate
I don't know what do more for NFC. In logcat and dmesg all good...@vm03 today i test nfc and it's not working, can i help with something?
Thank you sir@Tweakforce_LG Try an app called burn in cleaner its effective and removes the image burn in, ill try different apps for resolving burn in for different days with same amount of time and share the results with you
I will also test nfc on 08 build that im on next week and report backI don't know what do more for NFC. In logcat and dmesg all good...
... and how send my D3020f8 to vm03??You can send one d325f8 device to vm03 for fix your camera. Without device vm03 can nothing... Maybe he can, but there're so little chance...
Contact @vm03 in a PM for him to give you his address and depending on the shipping costs, it needs to get over to Russia. By sending VM a L70, don't expect it back (I may be wrong, but shipping costs in Russia is horrific). Pretty much a donation for development.... and how send my D3020f8 to vm03??
sorry for stupid question!!!![]()
Although for me if I send someone my device for development. Everyone would thank you for your kind effort to get the variant to the dev, in this case @vm03.
First of all, what is your Mail Provider in your country? (eg. USPS, UPS, DHL, ect)
Internal disabler patch for build 14 May 2015
https://cloud.mail.ru/public/2rqqJjRz4EDb/Patch/Disable_internal_CM12.1_14.05.15.zip
Credit:
@vladimirs77
So this makes it use your externalInternal disabler patch for build 14 May 2015
Credit:
@vladimirs77
Simple google search brought this:So this makes it use your external. If so how much slower is it on class 4 vs internal. And class 10 vs internal?
Definitelyoh boy, that's gonna be outdated real fast. considering these are nightlies.
IDK, i only have one sdcard class 4So this makes it use your external. If so how much slower is it on class 4 vs internal. And class 10 vs internal?
Installs it to sdcard.So using "Internal Disabler" makes installing large games with 2gb+ datas possible?
Thanks alot.
