Root Unofficial CyanogenMod 12.1 for LG L70 D320 D320n D325 MS323
Why are you asking everytime this question?
Wait for vm03 post. Probably only CM updates, nothing specific...
Well im asking becuse i would like to know where to view the cm update changes not just changes made by vm03 ect. If i can have a link to that id be greatful
Really thanks for this new CM12.1 and there is one problem: from CM12 my keys are not working well. My device is D320n and menu button acts as home and home button acts as nothing. Pls help me!! O BTW keys aren't working normally from last CM12 update.
are you using TWRP or CWM ? If CWM then you have to install TWRP.
Setting > About > CyanogenMod updates > tap the version or The update if avaliable, you will see the changelog there
Hello
My problem is that my D325 is recognized as D320 (# 3845 * 325 # - Factory Version: LGD320)
When I try this method to flash aboot:
dd if = / storage / external_sd / aboot.bin of = / dev / block / mmcblk0p6 bs = 4096
or this method: http://androidforums.com/threads/dump-all-variants-aboot-files-and-how-to-flash.918174/
I get the message: OPEN BOAT FOR READ: NO SUCH FILE OR RECOVERY
I got my aboot since my KDZ file (aboot_144384.bin and renamed aboot.bin) .. but still the same identification instead of D320 D325
Thank you help me please
I forgot to specified that the Roma custom installs without problem using TWRP only SIM cards are not detected.
Now I am restoring from TWRP and am under official ROM (but still identified as D320 instead of D325)
Problem solved .. I have put the aboot file (original) in the SD card and applied: dd if = / storage / external_sd / aboot.bin of = / dev / block / mmcblk0p6 bs = 4096
and the phone is now well recognized.
Only .. I have a new problem to get in RECOVERY mode : SECURE BOOTING ERROR
Thank you for helping me
I can't install twrp2860 , after unlocked the bootloader on my lg l70 320n. Somebody can explain me the steps. I open cmd where i downloaded the img files and for command fastboot flash recovery recovery.img the process doesn't start.thx
You need to place the img in your fastboot folder. Then shift+right click in the folder and open command window. Then proceed
This is the message,on my screen. FALSHIFY.APK can not install because it's insufficient space on my memory phone ( i have more 500mb free space), and changelog.txt I don't know how to use.
FALSHIFY.APK can not install because it's insufficient space on my memory phone ( i have more 500mb free space). I reset Google play services , and the message with insufficient space appare again.
Thank you very much ... it works
Some problem :
The play store and google apps not works
SuperSu (asks me to rott the terminal again)
Solutions?
Some problem :
Solutions?
Factory reset. The Google Play thing happens when system apps get corrupt (Google Play Services is missing). Reinstall CM and GApps.
