You know the folder you downloaded and used to unlock your bootloader. Copy recovery.img there. Tgen shift+right click in the folder and "open command window here". Than do the flashing commandFALSHIFY.APK can not install because it's insufficient space on my memory phone ( i have more 500mb free space). I reset Google play services , and the message with insufficient space appare again.
With CWM? No. OTA's won't accept on CWM. I don't why TWRP isn't working for you.Finally I instalated CM12....with CWM. I can install CM12.1 with CWM? twrp doesn't work for me...Any advice? thx.
Change .bin to .imgThis is probably a really stupid question but how do you download the recovery off that website, I hit download and nothing happens and when I hit download on my phone I get a .bin file which does nothing
Thank you, flashed it and its working fineChange .bin to .img
BJust popping in to say THAAANK YOOUU to all you skilled, patient, kind and helpful developers for making my ms323 such a perfect phone
Well, I admit I had my moments of despair, hehe... Softbricked a couple of times, but with the help of the devs over here, I succeeded in fixing aboot, laf, recovery & download mode (partitions). And my phone is repartitioned - system: 572mb, data: 2.65gb, cache: 28mb (after another softbrick). I fixed the data connection with *#*#4636#*#*
(Lte/wcdma/GSM auto PRL).
I'm now enjoying lollipop 5.1 - cm12.1 (with working rear camera) and sense 7 launcher (blinkfeed). I use Rondo Icons and Forto theme. My ms323 is smooth and snappy. I have a Samsung 32gb (class 10) card with ext4 partition, and I have link2sd pro available, but haven't needed it so far.
It's more than a perfect phone, THAAANK YOOUU SOOO MUUUCH![]()
?? Wipe system data cache in twrp than reflash rom..For some reason i lost root access when I installed the CM12.1 5-17-2015 Version and it wont let me go into the security panel so I can turn the "unknown sources" on to root my device. Is there any other way to root that doesnt require that being enabled ?
Every time you update you lose root access. Go to develeper options to enable itThis is probably a really stupid question but how do you download the recovery off that website, I hit download and nothing happens and when I hit download on my phone I get a .bin file which does nothing
Look around L70 forum, Lock Screen FC fix.The camera works thank you, also is the Hardware keystore is a big bug
Read few posts before. And you can find answer for your question.Anyone been able to confirm nfc yet?
Use fastboot not flashify. If you unlocked your boot loader youll have an ideaI instalated Flashify.apk,and now what version for twrp I must download , because lg l 70 doesn't show on list. thx
Read few post before your post and you can find answer for your hard question.What is changed latest update ? Except folder looking
are you using TWRP or CWM ? If CWM then you have to install TWRP.
What I did was downloaded flashify off the app store then hit "recovery" and clicked "choose file" and chose the file the recovery image I downloaded off this site (twrp 2.8.6.0) and it worked fine.I instalated Flashify.apk,and now what version for twrp I must download , because lg l 70 doesn't show on list. thx
Flashify works fine for flashing twrp, a lot more straight forward then the fastboot methodUse fastboot not flashify. If you unlocked your boot loader youll have an idea
