Root Unofficial CyanogenMod 12.1 for LG L70 D320 D320n D325 MS323
This is the message,on my screen. FALSHIFY.APK can not install because it's insufficient space on my memory phone ( i have more 500mb free space), and changelog.txt I don't know how to use.
write "fsdtboot" then hit the TAB. you should see "fastboot.exe" or "fastboot.bat" or sth like that. then write the entire command. e.g "fastboot.exe flash recovery recovery.img"
Actualice a la versión más reciente de este ROM, ese error ya está parcheado.
He asked about the security tab FCing and seeing as that's been patched, I told him to update to the latest ROM version.
Gracias Amigo! Crees que me pasas el link de descarga si no es mucha la molestia!
mmm tengo
Tengo descargada la version de 17/05/2015 y el problema es en esa version
Hey @vm03. Is it possible that you can see if you can fix the tiny bug of improper charging animation display when phone is charging when off. I find it helpful. Thanks for the rom you awsome developer!
You can say something different than "Read few post before"? If you only come to say that you can say nothing. Thx
OK, then we'll have all the same questions asked over and over and over.... It's much easier to do a few clicks and read than to pollute threads, methinks.
Read few posts before your posts and you can find answer for your questions.
If not, then read thread for cm12. Because is too hard read more than 200 pages... :thumbsdowndroid:
By the way, Google is new search engine, maybe you can find it on kickstarter. It's a good tool.
Use google like this: your problem lg l70 site:androidforums.com
Security settings force close on ms323. Can't activate unknown sources... Is there a fix? :/
Gracias! :) otra pregunta que otras cosas pueden funcionar mal en el ms323?
GRACIAS POR DAR SOPORTE A LOS DEL HABLA LATINA! SE LES AGRADECE!!
Google translation-
Thanks! :) Another question that other things can go wrong in the ms323?
THANKS FOR SUPPORT TO GIVE SPEECH AMERICA! THANK THEM !!
People have asked for English and the site rules support them.
En serio, por favor hable Inglés.
"Google Translate"
https://play.google.com/store/apps/details?id=com.google.android.apps.translate
Danke! :)
