Deadpoolddt
Member
Any fix for usdd codes? D320f8 here
NOPE!my model number is LGAS323 will it work with this rom?
NOPE!
actually, AS323 is a nother version of the L70 so... try it!my model number is LGAS323 will it work with this rom?
On my devices (d325 and ms323) no problem with ussd.Any fix for usdd codes? D320f8 here
Hardware is perfectly fine, if it can run lollipop, it will run M. The devs are thinking about porting itWill android M be ported to l70? Or will it not be supported due to hardware? Or?
We will look on it after release Cyanogenmod on M.I think yes. M is a big update, same device requirements as lollipop.
Maybe @vm03 can make device tree for M android, who knows![]()
Suppose one of the reasons this thread is a bit "quite" those days, is because most things works ☺
Absolutely everything works on my ms323 ☺
Repartioned my internal again after trying the internal on sd hack - a bit snappier with repartitioned...
Using Sense 7 as my home and xposed to fine tune...
Battery life is much better than on stock ROM and this low end phone is snappy and smooth thanks to you guys ☺☺☺
Thank you vm03 and all you guys involved in this project ☺
There is no reason not to, we'll just have to wait the final release. I mean, transit from kk to lp was mostly painless (although I joined development a tad bit after lp release), how hard can it be for M?Will android M be ported to l70? Or will it not be supported due to hardware? Or?
How do you Repartion your internal is there a tutorial
Asked it but nobody gave me answer regarding this. If you tried it please share your experience and thoughts about it.Just wondering if the kernel supports f2fs, and if anyone tried it on this rom ☺
Usually means you have to reset and wipe everything and reinstall ROM and GApps, there is no way to get out of that. I'm sorry.HELP PLEASE! I reinstalled gapps because apps like playstore weren't working after an update of this cm12.1 ota. Now I'm getting gapps process stopping errors. Please tell me I don't have to start from blank gain. Am I suppose to wipe cache or something?
Sigh. I'm done then. I'm not gonna use my phone and just gonna wait until Friday to buy a new phone.Usually means you have to reset and wipe everything and reinstall ROM and GApps, there is no way to get out of that. I'm sorry.
Slide over from left to right in the camera app, go to settings.How do I change the default location for camera photos? I don't want to use internal storage as the default location for my camera photos. I want to use my 64GB MicroSD card instead as the default location for my camera photos.
Anything happens when you flash a Custom ROM. We are NEVER responsible for your data losses.Sigh. I'm done then. I'm not gonna use my phone and just gonna wait until Friday to buy a new phone.
Never wiped or cleread any data on any ota and everything worked fine and also never need to reinstall gapps, but maybe its diffrent trough variantsSigh. I'm done then. I'm not gonna use my phone and just gonna wait until Friday to buy a new phone.
