Root Unofficial CyanogenMod 12.1 for LG L70 D320 D320n D325 MS323
Hi guys
Great Rom, I need some help, in the settings menu if I try to open the security tab it quits and closes… ..any help I am using a ms323 with 12.1
Thanks
HELLO MY QUESTION IS WHEN IS TO CORRECT THE CAMERA BUG IN AY LG D325F8 GREEDILY ARE VERY MANY OF 12.1 CM TO USE THIS TERMINAL
camera for D325f8
I have a problem with CM12.1 on my d320n. Sometimes when i turn off wifi and turn on mobile data it doesn't really turn on, and i can't connect to the internet. I have to restart my phone and then it connects. Is there a way to solve this or am I stuck with this?
Also, insignificant problem - when i have autorotate on, the image will rotate to landscape but won't return to portrait. I have to turn it off, then on again, or go to my home screen. Another thing is that the location option in my status bar (or whatever its called) sometimes disappears and then it comes back somehow.
Hey guys im not sure if its just my phone but when im recording videos the camera looks stretched horizontally & everything looks ovalish /: does anyone know why ? Or is there a bug of some sort maybe ? Thanks ! Btw the work made for this rom is impressive ! Good job developers !
hello i have device configuration LG L Fino breed other lg snap8610 L70 but with 4 cores c you can any idea I would be grateful cm 12 you very much
L Fino very similar to L70. Fork my repos on github, add changes from stok kernel (config, dt, etc), and to device tree chenges for devices without hw keys, and try to build (how to build also in readme on github).
That's just for preview when you're filming, video is OK. Max resolution for videos was 640x480 (4:3 aspect ratio), but we bumped it up to 800x600 (16:10 aspect ratio). This resulted in preview to be "squished" but, as I said, video itself is fine. Try playing it back on your phone or PC :)
you can support the initial steps I build, I do not know how to build it works rom CM, you need to ask anything or anyone to contact me any trials. sorry my bad English ☺
Thanks, i saw the video afterwards and its right; i shouldve checked that first /: thanks though (:
add dt folder from stok to arch/arm/boot/dts
add defconfig to arch/arm/configs
add CM changes to defconfig
try to build...
I 'm trying to create a port for lg lfino cm12 you can help create test rom , thanks
https://github.com/OnlyCM
everything ready because my pc configuration not enough to buird bother you if you have time
