Hi,Does xposed work?
Same thing here ....I cant put the USB computer connection to Charge only :/
Does xposed work?
I maybe did something wrong or something else, because it did not work for me, it ended in a infinite boot loop :\ and I had to install it all over again. Tomorrow I will try again and keep my fingers crossed.Works perfectly for me!
Flash xposed-sdk22-5.1.1-arm-20150514.zip from recsta.
(Need to be reflashed after every rom update)
Install XposedInstaller_3.0-alpha2.apk
I use the following modules, but I'm sure there's plenty more working by now...
3c Toolbox Pro
Always Correct
ChromePie
Disable Su Indicator
Gtavitybox LP
Greenify
Network Speed Indicator
Pandora Patcher
Swiftkey Goodness On More Fields
Good luck ☺
Read this http://androidforums.com/threads/d3...srom-2-1-official.915761/page-12#post-6996414(Need to be reflashed after every rom update)
Thank you!That's weird ???
Always worked for me...
This is off topic so I recommend you to look up the forums on XDA...
(Edit) there's newer versions, but the ones I recommended are safe what I know. Something about selinux and what recovery used...
https://mega.co.nz/#!BhpAFALB!2SZIRMoUWs4K8OTuxnQmwr_FWz6GRMDQTMyd2G43ws8Help does anyone have original kdz file for d320n?
The links at : http://www.lg-phones.org/official-stock-lg-l70-firmware-rom.html are dead.
Lol I think my magic ball needs to be polished because I never see anything when I really need it thanks I appreciate it , everyone here has taught me a lot and haven't been dicks to the new dude unlike certain other places, a week ago my expertise stopped dead at a basic root ..in a week I've completely pimped out 2 phones lol..now if only I had a way to yank my gpad out of the bootloop its been in 2 months now, I could really have some fun![]()
Magic ball, magic ball, please show me the answer!
(by the way, yes, this rom is pre-rooted)![]()
Rename your hotspot name if you're using AndroidAP. You're laptop probably uses the previous password.I can't share internet trough wifi zone to my laptop, only works without password being set and i don't know how to make usb modem mode to work any idea?
D320f8
It worked, thanksRename your hotspot name if you're using AndroidAP. You're laptop probably uses the previous password.
