Root Unofficial CyanogenMod 12.1 for LG L70 D320 D320n D325 MS323
hey, guys, i have a problem with my device, i flashed wrong aboot.bin and this is my problem:
DBI Err Fatal!
DemiGod Crash Handler : DBI Err Fatal!
Board Rev.:1.0
Ram dump mode.
Option : SD card ram dump mode.
Push below files to sdcard before test.
rdcookie.txt, rtcookie.txt
Please do folliwing action.
1) Ram dump Mode. Please connect USB.
2) Get the ram dump image using QPST Configuration.
3) If sdcard ram dump enabled just wait for reboot.
4) Collect ramdump files from your pc or sdcard.
5) Send e-mail to W5-BSP-Global@lge.com
sees the image, my model is LG L70 D320g8, what i can do? help me please
There's something that bugs me, when the phone is off and charging there's a delay for the animation to show and also the resolution of the animation is wrong (its very small), there's some way to change that animation and also set the delay?
D320f8
D320f8
That also happens also in my ms323
D320f8
video drivers are slow to load, just like in cyanogenmod recovery. This slow load, however, doesn't affect charging in any way.
This camera has a lot of background noise. Is it the app or the Rom. If it's the app what's the next best camera app I can replace with. Any suggestions
DBI Err Fatal!
Board Rev.:1.0
Ram dump mode.
check this: http://androidforums.com/threads/dump-all-variants-aboot-files-and-how-to-flash.918174/
DBI Err Fatal!
Board Rev.:1.0
Ram dump mode.
Your Phone now cannot be saved!! :(
I had same problem and now my phone is without Imei number and it just keeps showing this errror in evry 10 mins!
I had the correct aboot.bin and CM12.1 worked fine for a week and after that it started showing this error
I fixed one imei number though but of no use now i will buy a new one and definetly it will not be lg :)
DBI Err Fatal!
Board Rev.:1.0
Ram dump mode.
to fix the problem you have to restore download mode and install kdz
Why I cant update using OTA to the new version? The check for updates is working but when i press the download icon nothing happens
