Lê Quốc Việt
Member
new version: android 5.1.1_r3 -> 5.1.1_r6
thank man !!
thank man !!
No. I not modifying CM, only porting it to L70. And for me cm music player working without problem.hi . the default music player is not so good and it always crash ! can u change it to another ( like walkman) in the next update? tnx
https://cloud.mail.ru/public/2rqqJjRz4EDb/Patch/Cm12.1/can you make Disabler internal sd in CM12.1?
Yes. Currently only performance profile in battery settings.no performance in the latest update?
Camera is working great on my device d320nthe camera doesn't work in LG L70 D320n, cm12.1 last version 10/07/2015, what can i do?
but I can not make it work, and I have the same model with the latest versionCamera is working great on my device d320n
how i do it? about aboot.binflash right aboot bin and new twrp...
I had that issue on my ms323 and the issue was that i was using a CM Recovery instead of a TWRP I flashed it over CM using ADB. May not work but its worth a shot.home botton and options do not work in in d320f8
i was using TWRP 2.8.7, but now the buttons do not workI had that issue on my ms323 and the issue was that i was using a CM Recovery instead of a TWRP I flashed it over CM using ADB. May not work but its worth a shot.
showi was using TWRP 2.8.7, but now the buttons do not work
