Root Unofficial CyanogenMod 12.1 for LG L70 D320 D320n D325 MS323
please teach me how can I fix the camera's d325 this rom, I will responsibly. I've tried many forms, such as VM3 said I sending cell he gets as he do that? It's impossible to send so I want to learn
Strat from here http://www.tldp.org/LDP/lkmpg/2.6/html/ . Then google more about linux kernel develpment (include device tree). Then read l70 kernel source from lg and my github and find code for camera and try to fix problem for f8 camera.
I notice there's update for the rom available. If I update won't I lose data? Is there anyway for preventing losing any data to upgrade. Please respond
You don't lose any data. Just install and enjoy, wipe davik cache when done though.
And if you use the ota update, and have twrp installed, when you reboot the update script will take care of all, including wipe of dalvik, you just have to do nothing :)
vm hello, I really liked your artificial rom. and can I make modifications to this rom? I'm sorry if my english is not good. from Indonesian users
I was in big trouble and couldnt understand whats going on!
I installed CM12.1 a week ago and it worked fine for a week then suddenly one day it shows a pink screen,
DBI Fatal err!, sdcard ramdump bla bla
I rebooted then again aftersometime it showed!
i factory reseted and started phone after sometime it hanged so i removed battery after that it didnt switched on for whole night!
Suddenly in the moring i connected it to a laptop with a usb cable and magically this time it turned on but as soon as i was going to restore Stock rom with cwm backup the screen became jagged and Cwm stopped kinda i removed battery and in next boot it showed the pink screen again. After removing battery again now its not switching on at all again.!! and i am stuck!!
Vm03 u are a great dev but just check the kernel for this! and pls if u could let me understand what was the problem! I am learning Kernel Modification and Porting! (p.s. it was stuck in boot loop after it switched on in morning)
EDIT: Atlast it booted again i am reverting to stock rom! Fingers crossed may it complete successfully this time!!
Looking forward for ur reply
Link to github in first post.
You changed kernel? If no, i think you have hardware problem.
No! I didnt changed Kernel! It happened automaticaly nd now its also happening in stock rom sometimes !!! pls help someone!!!!
Can you guys make a internal Disabler and if your did what cm12 did you make it for and what's the link for the Disabler great ROM by the way just low space on ms323
Bugs List i found:
-Chrome Cast does not work
-Video on camera does not work but social apps do read it the video
I've been randomly saying bugs through out the thread I found but here is a list for those of you who are curious.
-Headphone buttons do nothing
-Quick button works the same as the power button
-WiFi & Data randomly turn off showing a "!" before unlocking and it fixing itself a few seconds later.
-Screenshot from power menu won't work sometimes.
-Apps disappear from home after reboot and if they were protected in a folder it just makes a huge mess.
That's all of them at the moment. Even with these annoying bugs the ROM is really awesome and I love it more then Stock.
Bugs List i found:
Video most definitely works. Don't know about Chromecast, though.
1) yes, that doesn't work;
2) Yep, that's how vm03 programmed it, I think. If you have a suggestion for the action, please don't hesitate to throw idea or two here :)
3) Data is dropping because of not-so-good network coverage where you are. Wifi drops, you can remedy that by changing timeout of wifi sleep policy. When your phone is locked wifi disconnects to save your battery and connects on intervals to check for any new stuff. I think default value is 180 seconds, and you can lower that, but I suggest leaving it that way or you may suffer severe battery drainage. You have been warned :)
4) Screenshot should be ok;
5) Apps disappear because you moved them to SD. Move vital apps back to phone. You mught wanna consider repartitioning your internal memory if you lack space.
Guys, I know this has been asked a lot of times before, but I still get that error message:
Android keyboard (AOSP) has stopped.
I have L320n, CM12.1 and after I installed gapps (tried both nano and pico) this is when the problem starts.
I've also tried force stop the app, delete cache, dalvik cache, do a full format and install fresh copy of the OS and many gapps versions and nothing works. I also tried to replace the Generic.kl file with the one suggested by a member of the forum, and still nothing! The error keeps on appearing.
Suggestions? Please help.
Turn on Superuser in developer mode, Use some app like Link2SD to delete system apps, delete Android keyboard and donwload another, there is plenty apk of aosp even with themes around there
For the button I would suggesting an easy way to remap the hardware buttons since it use to be a quick button(shortcut) for an app you choose. Also for the sleep policy for the WiFi its set to stay on "always" that's why I mentioned it mildly frustrating, kind of sucks but data has been working better so might have been a fluke. Some apps stopped disappearing after a while when I started using "Link2SD" to manage.
Yeah, link2SD is a viable solution. The mentioned 180 seconds are fot that "always" mode, I believe :)
