Add to your /data/local.prop, or to your /system/build.prop qemu.hw.mainkeys=0, and reboot.How do you get navigation buttons?
At the end of your fileAdd it anywhere?
I got it, thanks.At the end of your file
Glad to helpI got it, thanks.
Reflash rom...wipe system and cache.. Don't forget flash via TWRPThanks for the great work on the Rom. Its awesome! I have couple of issues that I am having, and they may have been asked already or in the works. So I apologize if they have been. I have ms323.
First issue- cannot uninstall any apps I have downloaded from the playstore. When I try it reboots the phone. Then when it restarts the app is still there.
Second issue- the hard buttons are not working as I thought they would. The home button doesn't seem to do anything and the menu button acts like the home button should.
Thank you for your time and all your hard work!
Thank you, I am trying that now.Reflash rom...wipe system and cache.. Don't forget flash via TWRP
Did you flash the twrp? and after that use twrp for flashing cm12.1? If you use as recovery cm, it will not work.Only issue I have is the menu button works like the home button and Home doesn't work at all. Also for data it says HSPA.
Alright thank you ill flash twrp anything I should know besides this?Did you flash the twrp? and after that use twrp for flashing cm12.1? If you use as recovery cm, it will not work.
He was right TWRP fixed the button issue but now I have an issue with metros 4g dataWhat variant model you have? There is already a fix for that
Personaly, I do a wipe of all partitions-data, system, cache, and dalvik to have them clean and freshAlright thank you ill flash twrp anything I should know besides this?
When someone sends an F8 to @vm03. I'm guessing that's the variant you're talking about since it's the only variant now that has a broken camera.Hello, good, I know my English is very bad but I just wanted to ask how to be ready when the fix for the camera?
There is not a solution until @vm03 gets the F8 sadly. They may never be one until he gets an F8.If what I'm talking about @ VM03, is there a solution?
Lo que tratan de decirte es que @vm03, no puede solucionar el bug de la cámara para nuestro modelo D320f8 hasta que tenga uno en sus manos, o alguien le envie uno.
What they are meaning is that @vm03 can't fix the camera bug for our D320f8 variant until he gets one into his own hands or someone sends one
