Root Unofficial CyanogenMod 12.1 for LG L70 D320 D320n D325 MS323
Hi all
I just installed new update ang playstore won't let me download anything says something about server error this happened last update and had to fresh install everything to fix
any help???
Save your Contacts ;
Settings/Apps : Force stop “Google Play Store” & “Google Play services” (!) ;
Settings/Accounts : Remove Google account ;
Reboot ;
Re-create your account under Play Store app & try download something ;
Import your Contacts ;
That’s all !
some changes in the phone takes too long to load the battery @vm03
Yeah, this happens to me too, @vm03 thinks phone needs few full recharge cycles.
vm03, it came to my mind that /data/system/batterystats.bin holds some battery info. Now, since it resets itself in 90 days (if I remember correctly), I thought it might hold info prior to lge battery code patch. So I deleted it, and of course, it didn't helped. Clean flash also doesn't work. Just thought of sharing tis with you.
Hi my friends.my cyanogen internet browser shows error and does'nt work when i use mobile internet(3g,...)but i dont have problem with whatsapp and other things.
and its ok in wifi.what should i do to fix it?
First try to clear the browser's cache from settings-apps-all-browser-clear cache; or you can try a different browser to see if you have the same problem
Hello. I just notice something strange....
My phone reboot by it self a few time already after the flashing.... until now about 5 reboots with around a week that has been installed...
Any Idea?
I went there and did what it said and it bricked my phone cx i accidentally reset my 32 gb sd card x) i lost everything on my phone d: luckily i had the stock software on my computer and flashed it with the flashtool d: idk what i did wrong though :c
It should be discussed on that thread, but if you follow the instruction nothing bad will happened, just be sure to read the posts and follow the instructions!
Brgds!
I think my phone isn't supported its the ms323 not d325 :d
It is pretty easy to re-partion your phone's memory as described in http://androidforums.com/threads/repartition-internal-memory.907534/page-7#post-7067095, and with minimum knowledge you can do it, it is all about identifying your partitions (/userdata, /cache and /system, knowing a bit of parted commands, such as parted -s /dev/block/mmcblk0 print, or rm or name, identify the begining and the end of sectors and you are done), but if you are not sure, do not do it! you can brick your phone! Good luck!
thanks, ill try again (: & is there a way to port the stock camera to cm12.1? Im on stock right now and i lke the camera better :d especially because the focus can be manual so it has more manual controls :d
thanks, ill try again :) & is there a way to port the stock camera to cm12.1? Im on stock right now and i lke the camera better :d especially because the focus can be manual so it has more manual controls :d
I do not think that the stock camera will be ported to cm12.1; why do not give a try to snap from Google play? It was suggested to by @Maslovicz, and I keep using it- thanks @Maslovicz
