Root Unofficial CyanogenMod 12.1 for LG L70 D320 D320n D325 MS323
Turn off superuser in settings
Turn off and on phone (not restart)
Repeat steps until work
It's a weird kind of "bug" that makes wifi and data not work when the phone start with superuser privileges, this steps works for me every time.
Ps: you can turn on superuser privileges after phone is on
I tried doing that and it still doesn't work /: when I connect to WiFi it works but not on the mobile network.
Yeah thanks ! I'm not a pro like everyone else d: but I'm willing to learn :) & one more question; I flashed cm12.1 earlier and I've been trying to connect to my mobile network but it won't let me idk why. I changed the settings from the APN and it still has an exclamation mark /:
For sure you have something wrong in your mobile network configuration.
Double check it. Also recommend to compare with another phone same as yours, and copy the configuration from that phone to your phone.
That's the way I did with mine.
@vm03 the lockscreen vizuliser used to work on soundcloud and the music app, but lately it doesnt work on soundcloud unless the individual song has played for a long time. E.g. a long music mix of 1hr
Can confirm, I'm on an ms323 and am having the same issues. It worked before, but then I tried upgrading to the latest, but had audio issues; so i downgraded to the 08/29, but then the mobile data stopped working. I tried 08/08, 08/22, and it's still not working. Maybe it's something with lollipop?
Check APN settings.
I'm sorry but i have a question, somehow after i flash the rom my phone charges super slow , is there any way to fix this. Thanks
Check APN settings.
Alright, thanks, that seemed to work. I had to compare my settings against another phone someone had, and using their settings fixed mine.
@luis762 make sure your apn settings look like this if you're on MetroPCS:
APN: fast.metropcs.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMSC: http://metropcs.mmsmvno.com/mms/wapenc
MMS proxy: Not set
MMS port: Not set
MCC: 310
MNC: 260
Authentication type: Not set
APN type: default,mms,suplex,hipri
APN protocol: IPv6
APN roaming protocol: IPv4
APN enable/disable: (can't do anything here, ignore it lol)
Bearer: Unspecified
MVNO type: GID
MVNO value: 6d38
After the latest update?
Is it only me?
(ms323)
On D320n i have problem with brightness, I can't change it. I'm moving the cursor but no matter is it on min or max, the brightness of the screen is the same, some predefined I guess. I'm on the 29.08. CM12.1 update.
Anyone else have this problem?
Tjank
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: Not set
MMS port: Not set
MCC: 310
MNC: 260
APN protocol: IPv6
Bearer: Unspecified
MVNO type: GID
MVNO value: 6d38
Thanks it finally worked (: all of y'all guys are so freaking helpful (:
Like mentioned earlier I'm having problems adjusting brightness Im on the latest build. It was like that in the previous one. Any suggestions
Como la compraste
Welcome to Android Forums Kevinfloreslool :) Our forums are English speaking only, so every visitor and member can contribute to the conversation. Please use a service like Google Translate if you need any assistance posting in English. Thank you!
