Root Unofficial CyanogenMod 12.1 for LG L70 D320 D320n D325 MS323
I am using Lg L70 D325, This lolipop rom is great:). Everything works fine on my device except the camera....... there is so much digital noise on image:(....., also the kitkat version rom has the same problem. I was waiting for a long time for you to solve this problem. I wish:( you solve this problem soon or tell me a way to solve this. It will be very helpful ..... Thank you:)
I think this is a device problem, not a software problem.
L70 have crappy camera...
Can someone give me a link to get to the updated internal disabler zip please, thanks in advanced.
Update, Nvm I found what I needed.
PLS HELP!!!
I can't access the security settings in the ROM. Whenever I select the security tab in settings, settings shuts down. I can't install any apps because of this.
P.S I have the MS323
PLS HELP!!!
Same thing but with the data usage section, settings force closes
D320f8
PLS HELP!!!
D320f8
Did y'all flash with the latest twrp?
Also has anyone else format their system and data partition to f2fs and test it out for better performance?
I think slow charging is finally addressed on the 0919 version. Tested on my D325.
nope :( ( on the 0919 build, D325)
Here's my screenies.
You guys should try recalibrating your batteries, draining to 0% then charging up to 100 continuosly,
A little problem i have found. It ain't a big deal but when starting FM radio in landscape (forced auto rotate) it crashes immediately.
Just wanted to tell.
Would be nice if nfc is fixed soon. Also would be cool if some software features where added. We should have a poll of features we want, and top one is attempted to add to the next update, could do this once every few months
Would be cool, but then it wouldn't be cm12.1 anymore, but cm12.1 plus those features. Anyway, it's up to dev to decide on that. Even then, there would be a lot of forking and cherry-picking, so it would be best to start a whole new project based on cm12.1. Just my opinion on this topic, let's keep original projects pure.
guys can you help me here please,i really like cyanogenmod 12.1 beacuse is soo much better than the stock room at peformance and battery life,but the only downside is the camera.I mean the camera quallity is just trash on cyanogenmod 12.1(stock cm 12.1 camera and google camera).Do you have any ideas how i could get the quallity of stock room camera and bring it to cm 12.1,or maybe make the camera a little bit better on cm 12.1.I mean the camera on stock room is good,not great but it takes decent pictures in low light,and night and then on the cm 12.1 room...on boy the camera is just so bad.Any ideas of how i could make the camera better on cm 12.1 ?
It's because the stock ROM has optimization for the camera to make it look better.
Sorry if it's off topic, but 75 pages later can anybody tell me is it worth upgrading now from stock? I mean is there any performance improvements other than removing bloatware? Or any camera/screen/battery improvements? I'm too lazy to read all the pages, but I'm curious about this. Is this just a design change?
