Root Unofficial CyanogenMod 12.1 for LG L70 D320 D320n D325 MS323
I've a D320n model and the camera don't work. Is really fast and with link2plus you can link all the apps. However xposed doesn't work in this CM version
xposed is working
With CM12.1 I get wifi connection error, after enable disable wifi, connection work. What's the problem? Any ideea? It's not problem from router....
i have flashed this rom and i no longer get the YesOptus (my carrier(Australian)) boot animation i got with my stock rom so does this mean im fully network unlocked or still locked to my carrier?
lol wtf, my "options" button (the 3 lines on top of each other) is home, if held opens app switcher, then the arrow is back as per expected but why the hell is my home button not the home button, and the options button is the new home button and not options. this is rendering my home button useless, i guess ill use software buttons for now instead of hardware buttons until theres a fix for it, i love my hardware buttons to have correct functions but i can wait. great build except for that, keep up the good work
It's a bug in the Rom specific to these models lol I do believe there's a zip file you can flash to fix it somewhere if you dig around. I used to love hardware buttons too but now I can't use it without soft buttons for some reason
i just made a really bad most likely an amateur mistake, i was restoring my stock rom but it said that it couldnt restore /system so i thought "oh yeah, ok. ill just boot back into cm12.1 and go from there" but after rebooting and being stuck on the lg logo for 2 minutes i realized that restoring 1 rom mustve completely wiped the other, now mt phone has no rom to boot into im guessing, all i know is its stuck on the lg logo, what should i do to fix this?
i cant even go into recovery using the key combo and adb wont even recognise the device as connected
LG-D320TR key support will be added to next build, check it after release.
Hello again...
I did try yesterday this release; cm-12.1-20151003-UNOFFICIAL-w3ds.zip... But nothing chnaged yet... You were mean this release, or i need to wait next release? Or you need more information for my cell phone?
Hello again...
w3ds???
PS: But fix add to wrong repo. Wait again next release...
w3ds???
Sorry Sorry :( I did copy and paste here wrong... :( w5.zip... I did install the correct ROM because of i did update inside of the cellphone it self... I am sorry :( I did type here wrong... Sorry... Any way... You mean i need to wait for next release?
Hello i use an D320N and i encounter a problem since the last update i think cose a few weeks ago it was working with the hotspot i turn it on and in a second it turns off and keeps turning on and off untill i get error . i did try reboot but the same . pls help .
Thanks
hi @vm03
i have problem with charging in latest update and the other updates since 02/8
can u solve it ? the charging time is so slow.i wanna use the latest update with normal charging:( plz fix it .tnx
