Root Unofficial CyanogenMod 12.1 for LG L70 D320 D320n D325 MS323
10/10/2015 zip downloaded from PC and from mobile and tested several times and does not pass both the bootanimacion one else has this problem @vm03
@vm03 im on second to latest update, 08 or something, and spinning charging animation is frozen, does not spin. But when i pull down the notification menu, the charging status in there spins, but doesnt on normal status bar
Am i the only one facing the heating issue? Now, i'm on second to latest update. When i open games, the battery's temperature rise to more then 55 celsius. And when the battery's temperature reach 55 celsius, my phone won't charge. It'll charge if the temperature under 55 celsius. How to solve that? Sorry for my bad english.
Thats odd. I have a bug where the charging animation on top bat doesnt move. I do notice mine get warm, but it continues to charge. I suggest going back to an older versoin or backup you made for now, or just dont game until its fixed, becuse battery temps that high could risk triggering thermal runaway leading to fire or explosion.
I also facing that bug where the charging animation on top bat doesnt move. Another problem is the slow charging. Does that bug already fixed in the latest update(10-10)?
Btw, which rom is better between this rom(cm12.1) and aosp? Sorry for out of topic. Just asking [emoji1]
It save your battery from damage. It can bang if overheated.
Ayy @vm03 can we look into this?
Is 43c safe battery temp
I'm running the lg ms323
seems like xposed framework causes bootloop on 10-10, also when it boots I can't get into the playstore it says I have no Internet connection even tho I do. I forgot to make a backup before flashing this, screwed up my phone big time. They should take down the 10-10 download since it's confirmed not working
Hi
i was flash again v75 of Xposed official from http://forum.xda-developers.com/showthread.php?t=3034811 (sdk22 zip file)
and it was successful.
Now, xposed was run on v20151010
thank all !!
I can't test the new version since update add lge battery code :(
Because I have very slow charging
I hope the devs will be back it to normal again
how to fix "only position independent executables (PIE) are supported." when open game guardian and game killer ... pls help me ..
