Root Unofficial CyanogenMod 12.1 for LG L70 D320 D320n D325 MS323
@vm03 can you edit the rom to not use internal sd (/data) (or you could make flashable .zip that edits the filesystem not to use internal)it will help me a lot,becouse the restrictions in this price are small internal(so you cant download so much) if you can help me with that i will kiss my monitor( i want to download as many games as my sd card could fit 16gb)
Nice job,and continue your work,your a great man.
By the way i know that are other ways,but trust me,none is that good,just simple disable /data and ROCK!
I like this rom alot.
:D
:D
We all have to work a little ☺☺☺
http://androidforums.com/index.php?threads/887942/
Make SD card as internal memory
http://androidforums.com/index.php?threads/908126/
SD hack for storage expansion
Hello;
I love this so so much... Works so fine generally... But i have an internet problem... Wifi works fine... But 2G/3G doesnt work fine :( Is this ROM issue? Or this is my problem? I can not be sure ofcourse... I send my Baseband version etc... Is there any idea why i have an internet problem?
PS: I dont mean i can not connect internet! I mean most of the time i lost the connection... Generally I have an exclamation mark... And i loose internet connection... This happens so often... :(
Hello everyone :);)
They have not yet solved the problem of the camera for d320f8?
Please answer Ü, because....
I need help ASAP guys, can you help me?:nailbitingdroid:
I installed this version of Cyanogenmod 12.1 on my LG L70 MS323, but it's giving me a lot of problems. For example I can't enter in the Security Configurations, I cannot uninstall the apps I download because the phone reboots by itself and the apps suddenly stop working or crash. I've been trying to return to stock firmware and get my phone the way it was and I've found several tutorials showing how to do so, like using the "LG Flash Tool 2014" or the "KDZ Updater". I've downloaded the .kdz files, both the MS32310d and MS32310c, and the LG USB drivers but I've had no luck restoring the phone. I get everything ready on my pc like the tutorials say but when I conect the phone to my PC and boot it into Download mode it won't recognize it and hence won't restore the stock firmware. I've been trying to look everywhere for an answer to why it wont recognize my phone in Download Mode, because I don't know if it's my phone's fault or CM's.
Anyone knows anything about this or how to fix it that could guide me please. I'm desperate here because I can't do much on my phone I miss the way it was!! :saddroid::saddroid::saddroid:
PS: I don't know if this helps any, but when I boot into Download Mode this is what I get on my phone:
fastboot_init()
Error: allocating memory for ssd buffer
USB init ept @ 0x7ab1000
udc_start()
-- reset --
-- portchange --
fastboot: processing commands
fastboot_init()
udc_start()
-- reset --
-- portchange --
Same thing shows here on my f8 but never really tried to go back to stock can anyone confirm it's normal?
Hey guys, I have kinda bricked my device, I can still access the LG Download Mode, and my PC recognises the device as connected, as in like it makes the same sound as a USB being connected but it doesn't register as connected,in ADB it says "Unrecognised Device" so do you think I'll be able to get the phone to boot into recovery mode, CWM, and flash a new rom so the device is usable again? I have a new phone to replace it, HTC Desire 820, but I want to know if my device is usable again. All it can do now is stay on the lg logo on boot up until the battery dies because it has no OS to boot into, and go into download mode. So if anyone can help, much appreciated and no recommending flashing kdz files, k
Like maybe flashing cm11 at least because the reason I have no OS is because I tried to restore the backup of stock that I had, forgetting I had StageFright virus malware whatever it is, but I had it, and I stopped the backup half way through meaning there was no bootable OS, and I booted expecting to boot into cm12.1
