Root Unofficial CyanogenMod 12.1 for LG L70 D320 D320n D325 MS323
I'm running the lg ms323
seems like xposed framework causes bootloop on 10-10, also when it boots I can't get into the playstore it says I have no Internet connection even tho I do. I forgot to make a backup before flashing this, screwed up my phone big time. They should take down the 10-10 download since it's confirmed not working
Tried to reinstall google play services?
love this rom, im on the ms323. only thing is i wish there were more space on the system partition. after i flash nano GApps and Xposed i only have like 4mb of space left on sys partition, BIG THANKS to vm03 for making this great rom for such an inexpensive phone!
Link2sd is my cure its the only way I can even play with this phone , just gotta figure out which apps to not put the internal data on the SD cuz they won't perform as good. But balance it out and you'll never run out
Yes link2sd definitely saves this phone but I stay away from linking system app updates after my last SD card failed, had to get to my PC to reflash since all critical GApps were broken even tb couldn't help, that's why I rather flash the updates instead of linking them, but the open GApps are slightly bigger then the ones in the original post
I don't link system apps at all but I can see that being an issue
