Same problem for home key to me.LG-D320TR key support will be added to next build, check it after release.
And it has begun...@vm03, where is our cm13!?!?! We need it NOW!?!?! ZOMG!!!!![]()
Unbuildable now...@vm03, where is our cm13!?!?! We need it NOW!?!?! ZOMG!!!!![]()
Your have model.name=LG-D320, use latest TWRP.Same problem for home key to me.
Here is the output of cat /proc/cmdline
root@w5:/ # cat /proc/cmdline
cat /proc/cmdline
console=ttyHSL0,115200,n8 androidboot.console=ttyHSL0 user_debug=23 msm_rtb.filter=0x37 androidboot.hardware=msm8610 uart_console=disable lge.rev=rev_10 lcd_maker_id=lcd_secondary gpt=enable androidboot.mode lge.bootreason=0xffffffff androidboot.laf androidboot.dlcomplete=0 lge.battid=DS2704_L model.name=LG-D320 lge.kcal vmalloc=400m lge.hreset=off lge.camera=hi543_cowell lge.fmradio=1 lge.nfc=none androidboot.emmc=true androidboot.serialno=LGD3204a11dae0 lge.signed_image=true androidboot.baseband=msm mdss_mdp.panel=1:dsi:0:qcom,dsi_v2_tovis_shrink_wvga_video
You know I was just kidding, right?Unbuildable now...
external/curl/lib/ssluse.c:94:24: fatal error: openssl/ui.h: No such file or directory
#include <openssl/ui.h>
target thumb C: libcurl <= external/curl/lib/telnet.c
compilation terminated.
target thumb C: libcurl <= external/curl/lib/netrc.c
make: *** [/home/vasy/android/cm13/out/target/product/w3ds/obj/SHARED_LIBRARIES/libcurl_intermediates/lib/ssluse.o] Error 1
make: *** Waiting for unfinished jobs....
But I seriously tried to build cm13, but currently it unbuildable...You know I was just kidding, right?![]()
I believe in youBut I seriously tried to build cm13, but currently it unbuildable...
Currently it not my, it CM team need to do big work...I believe in you![]()
Yeah yeah, I know, the development just started, In no way I'm blaming youCurrently it not my, it CM team need to do big work...
Hello i use an D320N and i encounter a problem since the last update i think cose a few weeks ago it was working with the hotspot i turn it on and in a second it turns off and keeps turning on and off untill i get error . i did try reboot but the same . pls help .
Thanks
Wipe your device and flash again, be sure you have a updated TWRP.Help pls it dose this only when i have data connection on . if its off it wont disconnect and connect like crazy.
Except nfcWipe your device and flash again, be sure you have a updated TWRP.
On my d320n is working everything normally.
Yea you just need to wipe it all and start fresh with the latest cm update. But honestly that's sounds like you might have some other problems going on there too but you need to try a new Rom firstHello people of androidforums, I left a comment months ago ( Hey guys, i'm new to the forum and i flashed this ROM on my l70 ms323 METROPCS like 4-5 days ago. I did every right and the ROM is working "perfectly" fine. I'm having some problems though: 1) i cannot install updates with cmupdates, i can just download the zip file and nothing else; i tried going into recovery mode and install it from there, but it does not appear as zip (i renamed it to .zip right now, I'll update the post if it works). 2) i cannot open "security" in settings, it closes and says "unfortunately, settings has stopped." 3) i cannot install apks which makes me think i'm not even running android. I cannot turn on the function that allows me to install things that are not from google play since every time i try to turn it on it closes. 4) Every time i try to uninstall something my phone reboots and the app is not uninstalled; i have to move it to my sd card and then uninstall it, my phone still reboots for some reason. 5) My battery drains in no time; i charge my phone every night and in the afternoon now, I also turned off location and I lower my brightness several times. I would love to receive some help from you guys, thanks in advance!) Right now i'm running CM11 and since i'm sure things have changed, could someone please tell me what has been fixed? I really want to go back to 12.1 but i don't want to risk it and go back to point 0.
Is the new update the one in this thread or from cmupdates? Sorry for the dumb question but again i have problems with CMupdatesYea you just need to wipe it all and start fresh with the latest cm update. But honestly that's sounds like you might have some other problems going on there too but you need to try a new Rom first
YeahExcept nfc
Well it kinda depends on exactly which Rom you mean like AOSP, Tesla (Highly recommend), Slim, or do you mean just plain old CM cuz they are all based on the same cm base design,kinda lol not a dumb question man it's all good ..I will gladly point you in the right direction but try to PM me so we don't hog up the thread and I'll help you with whatever u needIs the new update the one in this thread or from cmupdates? Sorry for the dumb question but again i have problems with CMupdates
Yes, it's workingthe camera works lg d320?
