Quinn Hargraves
I want to try to flash this on my realm, although I have heard the touchscreen will not work if I do, any body know how to fix if it doesnt work
Repartition SD card and use Link2Sd...have fun doing mods to your deviceI nailed it with a pico TK_gapps package. So far all seems fine. Only problem left is that it says that it isn't enough space when trying to install some apps and, also, it doesnt want to install on SD.
Is it ok to use the MetroPcs ms323 variant, and would you recommend this over waiting for an official update from LG? Is there a camera fix?Cyanogenmod 12 for LG L70 D320 D320n D325
View attachment 79850 View attachment 79851 View attachment 79852
View attachment 79853 View attachment 79854 View attachment 79855
View attachment 79856 View attachment 79857 View attachment 79858
My port of CyanogenMod 12.0 for LG l70 D320 D320n D325. It is unofficial and unsupported by the CyanogenMod team.
Absolutely NO WARRANTY! You can brick and destroy you device!
For advanced users only. Please, no stupid questions.
For install need unlocked bootloader and CWM or TWRP recovery.
For correct working RIL (Sim detection) and keys you need correct (for you variant of L70) bootloader (aboot.bin).
Working:
Not working:
- Display
- touchscreen and multituch
- Hardware 3D rendring
- RIL - SMS, MMS, calls...
- Mobile data
- WiFi
- GPS
- Bluetooth
- WiFi, Bluetooth, USB tethering
- Audio - speaker, headphone, mic, routing, voip calls, etc
- Camera - photo and video
- SD card
- FM radio
- Hardware video decoding and encoding
- Sensors
- Double tap to wake
- SmartCover
- NFC on D320n
Download
- Rear camera for D325f8 and MS323
- Any others for unknown for me versions and revisions.
Last build cm-12-20150418-UNOFFICIAL-w5.zip
Gapps http://d-h.st/users/TKruzze/?fld_id=44392#filescm-12-20150131-UNOFFICIAL-w5.zip https://yadi.sk/d/QMPZZKBYePW7V md5: a57f787ff557856491b31ee6f0c8d73f
cm-12-20150125-UNOFFICIAL-w5.zip https://yadi.sk/d/X-zQjIYVeDnaW md5: 5f2bf656ff2d3b9bdb4675d0aa0dccea
cm-12-20150119-UNOFFICIAL-w5.zip https://yadi.sk/d/poRumQPXe6EUP md5: e79e26dad9f53aae0b5a8c7cd57bccb9
cm-12-20150117-UNOFFICIAL-w5.zip https://yadi.sk/d/lsnmUIs2e3y7a md5: 7080a2d5faf2a1551103ecd854809254
cm-12-20150110-UNOFFICIAL-w5.zip https://yadi.sk/d/dM7DnxOIdvWVXmd5: 6bb5fd368df7b1c53070a13b4bf9c682
cm-12-20150106-UNOFFICIAL-w5.zip https://yadi.sk/d/Mt0VGt3RdpJCY md5: abce7cee8b3a04051231603b2fa723c9
cm-12-20150105-UNOFFICIAL-w5.zip https://yadi.sk/d/IdZZrSyedoX37 md5: d375e7503b15559fab8d38eefd068fa1
TWRP v2.8.6.0 twrp_w5_20150328.img
cyanogen_recovery_w5_20150207.img https://yadi.sk/d/sxiBlfNfeZHaH unstable, no backup, wipe if enter by keys, slow bootup...
Source
Kernel https://github.com/vm03/android_kernel_lge_msm8610
Device https://github.com/vm03/android_device_lge_w5
https://github.com/vm03/android_device_lge_msm8610-common
Proprietary https://github.com/vm03/proprietary_vendor_lge_msm8610
- Copy zip's to SD
- Enter to recovery
- wipe data
- install zip from external_sd cm-12<...>.zip
- install zip from external_sd gapps
- reboot
Donate
Depends on what you will use your LG Device, I recommend it if you dont need access to your rearview cameraIs it ok to use the MetroPcs ms323 variant, and would you recommend this over waiting for an official update from LG? Is there a camera fix?
Ok but I need to know if it works for Ms323Depends on what you will use your LG Device, I recommend it if you dont need access to your rearview camera
I strongly recommend use cm12.1 (or cm11).Is it ok to use the MetroPcs ms323 variant, and would you recommend this over waiting for an official update from LG? Is there a camera fix?
Does 12.1 have any bugs, and does it work for Ms323? Even if all is fine, I probably wont be able to get it since I'm on version c.I strongly recommend use cm12.1 (or cm11).
Use CM12.1, @vm03 can you message mods to lock this thread and say there's an updated version in the OP? It's starting to get annoying people asking the difference between 12 and 12.1.Ok but I need to know if it works for Ms323
Yes it works very good, except for the camera better than CM, use the info from the other thread to fix your camera but get Nameless, not Cyanogemod.Ok but I need to know if it works for Ms323
They can do that in the 12.1 thread... But ok?Yes it works very good, except for the camera better than CM, use the info from the other thread to fix your camera but get Nameless, not Cyanogemod.
Btw LitrosNub, mods can do as they wish the thread, people are still coming for help in here
They can get the info to fix their camer on the LG MS323 but I recommend Nameless Rom, not sire why but it works better than CM for me..,so leave it up to the user to choose whicever rom they wantThey can do that in the 12.1 thread... But ok?
How can I fix the bugg camera on D320f8?
I no. But as i know CM supporting input and translated to Arabic.Hi vm03
Do you support the Arabic Language
ThanksI no. But as i know CM supporting input and translated to Arabic.
Look here http://androidforums.com/threads/twrp-ms323-d320n-d325-team-win-recovery-pro-2-8-7-0.911656/Hey everyone! Brand new to this site, usually I find myself on XDA forums but this seems to be the home for my friends' LG Optimus L70 MS323 that I am trying to get CM installed on. From all the work I've done so far, I've managed to root the device, but not install a recovery. Since this thread is over 100 pages long I figured I'd ask if anyone has found a way to install TWRP or CWM to this device instead of browsing for hours on end for answers. Thank you!![]()
Use 12.1!everytime i open playstore it close by itself
CM12 is outdated. Use CM12.1 is so much better than CM12 -_-[QUOTE = "VM03, pós: 6843354, membro: 1778641"]! Proprietários de D320 e D320n e ms323 favor testá-lo [/ QUOTE]
