it's a bit ugly, someone shares file manager?
You have to use right version of Aboot.bin
Just reinstall your CWM using this file
http://androidforums.com/attachments/cwm-lg-l-70-d325-zip.83666/
I have this problem before, because using aboot.bin for D320. You have to use aboot.bin pathced for D325
(hint: If your model name on setting didn't say D325, you're using wrong aboot.bin)
LG will never let the L70 have lollipop. There may be a port of stock LG lollipop for the L70 but not from LG.L90 got Lollipop, who knows when LG is gonna push out the Stock LP Update for L70. Probably never. But hey. Believe.
http://androidforums.com/threads/un...12-1-for-lg-l70-d320-d320n-d325-ms323.912225/Muy buenas, funciona para LG L70 (D320n)?
Alguien podría dejar los links de descarga por algún lado o podría pasarme el link a estos?
Muchas gracias!
Hey, It works for my LG L70 (D320n)?
Someone could leave the download links somewhere or could spend the link to these?
Thanks!
CM12 is not updated anymore.the project to fix the camera bug in D325F8 device was stopped?
Thanks Maslovicz. Another question. The rear camera works well? Generally everything works?http://androidforums.com/threads/un...12-1-for-lg-l70-d320-d320n-d325-ms323.912225/
Use CM12.1 is better. And read this thread for all your questions.
Volup+power. when you see LG logo, release power (still hold volup) and push it immediately.how I can access the recovery when the phone is off? what key combination I use?
The phone does not start with me CyanogenMod 12.
Thanks mortz! By the way, anyone know where to download the gapps of version 12 and 12.1?Volup+power. when you see LG logo, release power (still hold volup) and push it immediately.
it will ask you if you want to do a factory reset, press yes. you will enter recovery after that
Read OP thread and all pages in thread. There are answers.Thanks Maslovicz. Another question. The rear camera works well? Generally everything works?
Always use TWRP for flashing. That's even stated in the original post. Try wiping system also before flashing rom. For now, delete generic.kl in /system/usr/keylayouts and rename generic-D320n.kl to generic.klSo I installed on a LG D320n CM12, then updated to 20150603 (with CWM recovery). All running smooth and seems ok but... : Home button doesn't work at all and Menu button acts as Home. Also vibrating on touch does't work either.
Should I expect a fix?
It definitely works. Check in Settings/Display, and also is Homescreen settings.It worked! I used ES Explorer with root acces. Thanx a lot!
For double tap to sleep not working is there a fix?
Another problem... I tried so far 4 different gapps packages (5.0 from nano to full) but it keeps giving me errors like "unfortunately google partner setup has stopped" or ""unfortunately youtube has stopped". And the error keeps reappearing on a 3-4 seconds frequencie.
I even reflashed CM twice.
Maybe you could suggest gapps package that you know is working...
