Root Unofficial CyanogenMod 12 for LG L70 D320 D320n D325
Status
Not open for further replies.
Latest OTA update (ending numbers 214) fails and reboots when the progress bar reaches about 3/4. And yes I'm using CM Updater and when it fails it just goes back to the current version.
Hello There! I`m trying to flash my LG L 70 D320N with this room and on twr 2.8 recovery , when i selected zip to install i receive an error : this package is for device: w5, w5ds; this device is gammaw
then Error executing updater binary in zip ....
What can i do ?
just updated, back camera is not working
Yeah, but hold up. I flashed it from the server (downloaded the zip) right? And it told me that I am on version 2015-02-10, so I thought okay, and updated. It did not flash automatically (failed), but manual flashing of the zip worked - but it still says 2015-02-10!!??? What???
What can i do ?
I answer to myself :)
I found a workin` solution (i updated with gammaw instead deleted asert): http://androidforums.com/threads/change-w5ds-back-to-w5.894127/
Now it`s installed and worked ok.
Is it then updated to latest or not?
@vm03, I have some questions... I think I'm not the only one who don't know everything correctly, and if you will ask my questions, all the queries of everybody will disappear.
1. Right now, my phone have FastBoot (no Download Mode, no custom recovery as CWM/TWRP), and original Firmware. If I will install PhliiZ Recovery ( http://androidforums.com/threads/philz-ms323-d320n-d325-philz-recovery-for-lg-l70.889246/ ), I will be able to wipe Data/Cache/Dalvik or ART Cache (I'm not sure wich) and then to install CM12 with it, or I must use CWM/TWRP ? I think PhillZ is the bidder right now..
2. If I will install CM12 with PhillZ and everything will be fine, to update the software using the OTA System, we must go to Settings => About Device => Update Software ?
3. If the answer for point three is 'Yes', where will be the software downloaded ? On the Internal Memory ? And, wich is the smaller free memory we must have free on the Internal SD to be able to download it ?
4. After the download is finished, I think we probably have to click a 'Install Update' button or something like this.. After clicking it, the phone will reboot in a CM Updater, and we'll have just to wait ?
5. If the update will crash, I don't know why, will be the phone bricked, or just the software ?
6. When Updating the Software using OTA System, any backup is automatically made ?
Thank you adviced very much for your time!
I'm sorry if I asked a question wich was already asked, but I didn't found here an answer as I want... If you will answer all my questions, if someone will ask any of it again, I will quote your answer for it, for you to not have to answer over and over again the same thing...
Sorry for my English mistakes!
Status
