ledosladoledi
I'm not @vm03 but I'll answer questions I know...@vm03, I have some questions... I think I'm not the only one who don't know everything correctly, and if you will ask my questions, all the queries of everybody will disappear.
1. Right now, my phone have FastBoot (no Download Mode, no custom recovery as CWM/TWRP), and original Firmware. If I will install PhliiZ Recovery ( http://androidforums.com/threads/philz-ms323-d320n-d325-philz-recovery-for-lg-l70.889246/ ), I will be able to wipe Data/Cache/Dalvik or ART Cache (I'm not sure wich) and then to install CM12 with it, or I must use CWM/TWRP ? I think PhillZ is the bidder right now..
2. If I will install CM12 with PhillZ and everything will be fine, to update the software using the OTA System, we must go to Settings => About Device => Update Software ?
3. If the answer for point three is 'Yes', where will be the software downloaded ? On the Internal Memory ? And, wich is the smaller free memory we must have free on the Internal SD to be able to download it ?
4. After the download is finished, I think we probably have to click a 'Install Update' button or something like this.. After clicking it, the phone will reboot in a CM Updater, and we'll have just to wait ?
5. If the update will crash, I don't know why, will be the phone bricked, or just the software ?
6. When Updating the Software using OTA System, any backup is automatically made ?
Thank you adviced very much for your time!
I'm sorry if I asked a question wich was already asked, but I didn't found here an answer as I want... If you will answer all my questions, if someone will ask any of it again, I will quote your answer for it, for you to not have to answer over and over again the same thing...
Sorry for my English mistakes!
1. You can use any recovery made for our phone (I prefer philz)
2. Settings -> about phone -> cm updates -> there will show updates
3. It will download on internal memory and you need enough space for update ( I think 230 mb) and enough for phone to work
4. After download you can press on update and then install and the phone will reboot to recovery and that is the part u need cyanogen recovery (first post) but first install latest cm version with philz/cwm and then change to cyanogen recovery ( if you try to update without it the phone will just reboot to recovery and then u have to do it manually and then wait...
5. We need someone who knows what will happen
6. When updating using OTA there is NO backup because nothing is wiped... Your data is still there after update...
7. Hate it when ppl say sorry for my English and there is no mistakes... xD
