billyurbans
I have 800mb internal , and 6gb sd , but allows me to install only when set pref.location on internal or let system decide , when is on removable says out of space .
Try reboot If it doesn't help try wiping cache...I have 800mb internal , and 6gb sd , but allows me to install only when set pref.location on internal or let system decide , when is on removable says out of space .
I doubt it too I'm just guessing...I doubt , but thanx anyway
Download from PC and try itOK so after newest update it won't let me do the date fix script. Any ideas?
HUUGE mistake... It works im just dumb... Nothing new... Sorry for off topicUmm mobile data isn't working on oneplus one... Officially supported phone by CyanogenMod team... This is really big thing...
Don't have a pc for about a week need it fixed yesterday!Download from PC and try it
I will upload it as a post.Don't have a pc for about a week need it fixed yesterday!
Think I got it now. But before it would say h+ now it says e and it's super slow can't do anything. So you think it's because I'm not at home maybe bad signal?That's because the phone downloaded it as HTML code, not the real net.sh. People have been having problems with that. I'll hyperlink it so it doesn't download as HTML
This is from the one Zjala posted. http://fs1.d-h.st/download/00157/dPZk/net.sh
Click and it auto downloads. No need to go through site.
Oops. It bugged.
Click 'download now' and uncheck 'download with dev-host manager'. That should work too.
Did you downloaded it from PC? Sometimes if you download it from the phone it wont work like it should.Hey everyone, I'm new to the forums so forgive me for not wanting to read 48 pages of posts to see if anyone else had a similar issue. But I've been researching and trying to fix it for hours with no result.
To start I have ms323 (MetroPCS) version and I've flashed cm12 everything works perfectly fine so far but Data, I've done the workaround as in the OP and It doesn't do anything. Every time I try to go on the internet I get " err:HOST_NOT_RESOVED" I don't know if this is a model specific problems and the other hardware versions seem to be of more importance at the moment, I was just wondering if anyone else has a fix.
Forget about the device thing, muy fault... Is it a problem of your SIM card?Did you downloaded it from PC? Sometimes if you download it from the phone it wont work like it should.
If everything is ok, check the whole thread to see if it is a general error or just device especific. Also which device do you have? Dont forget that RIL doesnt work with D25 and that may cause the problem
Why you asking?the camera is working ?
Do you have the MS323? Because if you do - we know about the bug!the camera is working ?
