Root Unofficial CyanogenMod 12 for LG L70 D320 D320n D325
Status
Not open for further replies.
New update! 2015-02-17... What's changelog.. And I hope that update fix sim card for my d325
Okay, stop. This is a NIGHTLY ROM. If VM03 fixes anything device specific - he will let us know. UNTIL THEN - MS323 users; WE CAN LIVE WITHOUT THE BACK CAMERA - D32_F/G/WHATEVER obscure version of the L70 - same deal goes for yall. D325 - I really am sorry about your RIL - trust me I feel you. But asking if things have changed EVERY PAGE DOES NOT HELP. I am sorry for loosing it, but it is seriously concerning and upsetting this happens so often
I'm so confused.. I have put cwm file to internal and little setting in terminal emulator then reboot recovery but still load cyanogen recovery.. I have try it for many times and nothing... Anybody can help me to change cyanogen recovery to cwm.. So, i can restore my cm11 backup.. Because my sim card still not detected... Thanks for all and exactly the developers
Off topic to this thread. Move over to CWM/PhilZ thread
How can i change settings so i can use sd card as internal storage,and internal to be used only for apps and games....to simplify a bit, i want to remove internal storage from explorer,from media storage when i connect to pc, i want only to see sd card,and to be able to use it as storage for apps and games...
So Lollipop 5.1 is released. I'm guessing it will be automatically built from CM12 sources once they put 5.1 code there. Can't wait! Its got better RAM management and battery optimization.
Should I do a backup before flashing so I can return to stock if something goes wrong? I really don't want to be stuck on unofficial roms if something goes wrong
i shall, it's really beat up from when I was building skyscrapers but core fuctionality is still there if he can get out of the bootloop
This happened to me like 5 days ago... What I did was getting in CWM vía key combo, worked fine and was able to flash cm12 regularly and without any problem. Just try key combo and tell us how it goes!
Status
