Root Unofficial CyanogenMod 12 for LG L70 D320 D320n D325
Status
Not open for further replies.
I can't get it. I think I pretty much screwed myself
DRIVERS(if you dont have them)
http://www.mediafire.com/download/b...leDriver_S51MAN312AP22_ML_WHQL_Ver_3.12.3.exe
Try this:
1:
Pull out battery..wait 3 sec..then put battery back in..dont power on..hold down the VolUp key and plug in via USB to PC..i dunno what you did so you`ll get one out of three..if your phone boots into fastboot use this[1:(http://www.mediafire.com/download/fki9p90s0ll6fq0/LG_Laf_Recovery_Multitool_v1.2.zip)(extract anywhere)2:(http://www.mediafire.com/download/t3ear2a3kb8pe34/laf.img)(you`ll need this put it in same folder)3:(run as admin *run.bat* and you`ll see your device in list and use Choice D and let it do its thing)](once done pull out battery and do same procedure until you get Firmware Update and continue to next step after this
2:
If you get Firmware update use this [1:(http://www.mediafire.com/download/9u3twt5xoj9trrt/LG_Flash_Tool_2014.zip)(extract anywhere)2:(http://www.mediafire.com/download/dvp4196by3hutcq/MS32310b_00.kdz)(put it same folder)]..run *LGFlashTool2014.exe* as admin..on select type select 3GQCT..on phone mode select EMERGENCY..on Select KDZ File open the file you just downloaded from step 2 which would be *MS32310b_00.kdz*..click Normal Flash..you`ll get a pop up..leave all as is and click OK..itll run and let it do its thing..leave alone until it says complete..now pull out battery..wait 3 sec..put back in..press and hold VolDown key(or UP if it doesnt work)and Power..once you see the LG logo release power and press and hold again but keep holding VolDown key..if done correctly you`ll see Factory Reset Device?..use vol keys to make selection and power for OK..say YES..and let it do its thing..you should be back to stock in no time
3:
If you get Recovery..then you obviously flashed recovery to LAF partition..use recovery to factory reset..dont forget to format cache and dalvik cache. and use ADB sideload to flash ROM or if you have them stored in SD or Internal.
NOTE: If you want to go back to stock use steps 1 and/or 2
Try this:
1:
2:
3:
Next time, if possible, could you link him to a more appropriate thread before helping him with an off topic issue? :)
someone else tried..and it seemed it didnt work..so i gave him step by step of what i did to recover from bricked..actual bricked..Glad i helped
No thread btw..My steps..only thing i dont remember where i got KDZ and flash tools but kept a backup when needed..indeed i did need..Always Make or Have a Backup ;)
Im used to working with iOS and HTC devices..i gave up on iOS..they turned to sh*t
hi, i have a LG D325 mobile (dual). i flashed ur CM11 custom ROM and CM12 also. but i got a same problem with both ROMs. not supporting any SIM card. showing "emergency calls only" message. plz tell me how to fix this. i want to flash ur CM12 ROM. i dnt need to work with my both SIMs. just enough a working single sim. plz tell me how to fix this. plz hlp me....
(sorry for my bad english):(:(:(
Im new to this project but im pretty sure RIL is broken on the D325
Sure would be nice to post a link to a new members' question and help out. We're not like other sites ;)
Can't post a link to the thread were already on no point in giving him a link if its all over the place that it doesn't work. Just trying to clean up unnecessary posts.
Anybody for d325 (dual sim) have try to flash single sim firmware and then install cm12??? Im not sure it would help.. There maybe a chance to fix the ril problem.. Hope soon :)
New build after boot: ui.system is stopped working :D
Same here I got back to recovery and did a data whipe. It fired up but I have no su. When u try to get to it or try to set a lock screen it tells me setting's have stopped working.... Any ideas?
Status
