Maslovicz
Yes i know about thisCM12 is unstable...
LG didn't released Lollipop for any of their dual sim devices, not even for LG G3 dual. When LG releases Lollipop for any qualcomm dual sim device, then we will have a slim chance of making RIL workI hope soon the dual sim is fixed.. Cm12 is perfect
I'm sorry, do you mean it's still not working?but i restored my stock rom and nothing any problem now . why?
Try rebooting it in fastboot and then check if bootloader is unlocked... That is my only theory of not being able to access recoveryok so now im in a hard spot.. cant figure out how to get a new rom on this thing. after this mornings update im stuck with an ui has stopped working error. i have lost all root tried to manually su with app no luck. cant get back into recovery at all. i have a fresh rom on sd but no way to get to recovery. did i lose root and recovery?
Now im stuck in bootloop cant do anything. Tried to flash stock rom but it wont let me.Try rebooting it in fastboot and then check if bootloader is unlocked... That is my only theory of not being able to access recovery
U can't reboot to recovery?Now im stuck in bootloop cant do anything. Tried to flash stuck rom but it wont let me.
because i have a l70 d325 and i 'd put this rom in my device but is working the dual chip of the rom?Omg...
When will the RIL Fixed @vm03 ??
And I D325 Everything is slow and LaggY!!
It Lags Even plyaing Temple Run!
But your work iz truely appricited by me Tnx again
Mobile data is solved in this latest release (cm-12-20150214-UNOFFICIAL-w5.zip ) ?
is there any fix for the data in d320f8??? heeeeelp
No ril fixed in 0215 update
the camera is working ?
The rear camera does not work for LG L70 D320G8
Do you already working on the camera d320?
This ROM works for version d325g8 ??
hi, i have a LG D325 mobile (dual). i flashed ur CM11 custom ROM and CM12 also. but i got a same problem with both ROMs. not supporting any SIM card. showing "emergency calls only" message. plz tell me how to fix this. i want to flash ur CM12 ROM. i dnt need to work with my both SIMs. just enough a working single sim. plz tell me how to fix this. plz hlp me....
(sorry for my bad english)
you're bad as hell
No one wants this, from these folks or any rom dev. These folks do this in their free time, for nothing but their own satisfaction and maybe a meager donation or two that may add up to a fast food meal over the life of a ROM.If this behaviour continues, believe me that I would be totally cool with building private builds and sharing them via private messages only with a few selected people here who deserve updates. I speak in my own name, but I believe that vm03 will also follow my example, if you annoy him.
OK. THIS KIND OF BEHAVIOUR NEEDS TO STOP.
These are messages I found on a few pages before this one, I needn't got back further. What does this mean? That people don't bother investigating before flashing. And problems arise. Everything you do, you do on your responsibility.
On this subforum, main variants which are supported are: d320, d320n, d325, and ms323.
EVERYRHING ELSE is either totally unsupported or is working to some degree (e.g. camery may not work).
WE REALLY DON'T NEED SAME QUESTIONS ASKED OVER AND OVER.
When, and ONLY WHEN developer adds support for your specific variant IT WILL BE STATED IN THE ORIGINAL POST. There is no need to ask again and again, because you're pushing developer's buttons and consequently he may never add support for your device. EVER.
IF ORIGINAL POST DOES NOT STATE THAT YOUR DEVICE IS SUPPORTED, go thorugh thread and you will find your answer (what works on your variant, what doesn't). There is no need to litter thread with same questions and answers over and over. It is counter-productive!
From now on I speak only in my name:
Thank you for your time,
Yours sincerely.
Don't beat yourself up, I saw you asking nicely for help, which is a different thing. Whatsmore, I support that. I hate lazinessUnderstood, It's been awhile. And I'm not used to having a developer do nightlies so I thought they were totally different builds. Won't happen again.
understood. um noob here and sorry for anything i did wrong.OK. THIS KIND OF BEHAVIOUR NEEDS TO STOP.
Yours sincerely.
DRIVERS(if you dont have them)
http://www.mediafire.com/download/b...leDriver_S51MAN312AP22_ML_WHQL_Ver_3.12.3.exe
Try this:
1:
Pull out battery..wait 3 sec..then put battery back in..dont power on..hold down the VolUp key and plug in via USB to PC..i dunno what you did so you`ll get one out of three..if your phone boots into fastboot use this[1http://www.mediafire.com/download/fki9p90s0ll6fq0/LG_Laf_Recovery_Multitool_v1.2.zip)(extract anywhere)2http://www.mediafire.com/download/t3ear2a3kb8pe34/laf.img)(you`ll need this put it in same folder)3run as admin *run.bat* and you`ll see your device in list and use Choice D and let it do its thing)](once done pull out battery and do same procedure until you get Firmware Update and continue to next step after this
2:
If you get Firmware update use this [1http://www.mediafire.com/download/9u3twt5xoj9trrt/LG_Flash_Tool_2014.zip)(extract anywhere)2http://www.mediafire.com/download/dvp4196by3hutcq/MS32310b_00.kdz)(put it same folder)]..run *LGFlashTool2014.exe* as admin..on select type select 3GQCT..on phone mode select EMERGENCY..on Select KDZ File open the file you just downloaded from step 2 which would be *MS32310b_00.kdz*..click Normal Flash..you`ll get a pop up..leave all as is and click OK..itll run and let it do its thing..leave alone until it says complete..now pull out battery..wait 3 sec..put back in..press and hold VolDown key(or UP if it doesnt work)and Power..once you see the LG logo release power and press and hold again but keep holding VolDown key..if done correctly you`ll see Factory Reset Device?..use vol keys to make selection and power for OK..say YES..and let it do its thing..you should be back to stock in no time
3:
If you get Recovery..then you obviously flashed recovery to LAF partition..use recovery to factory reset..dont forget to format cache and dalvik cache. and use ADB sideload to flash ROM or if you have them stored in SD or Internal.
NOTE: If you want to go back to stock use steps 1 and/or 2
I would say more..he tried to fix the problem himself but didnt work for some reason..it okay not all threads are helpful..and seeked advice and we were here to help...He tried and didnt give up..he was also willing to donate a device for testing.Don't beat yourself up, I saw you asking nicely for help, which is a different thing. Whatsmore, I support that. I hate laziness
Como ya dijo @DevMyAndroid , no se puede controlar ese problema, y ademas ese problema es mencionado en CADA PAGINA de este foro... Se recomienda leer antes de pedir ayuda. Ademas, no puedes presionarlos a arreglar algo, ya es mucho trabajo hacer un ROM para este dispositivoHola , has podido reparar el bug de la cámara trasera? Tengo un l70 D320? he probado una ROM y tenia ese bug
