xRaZeR_FuZioNx
That absolutely makes no sense, the RIL problem is a technical problem with the Kernel, not the software. [emoji58]Can I download RIL for d325 ? my friend said it maybe would help..
Word of advice - both zlaja84 and myself have both gone down the zip porting game, trust me when I say you don't want to do that. Just go ahead and take the time to learn how to source port. As you already have sources for CM11&12, it shouldn't be too hard (I was going to, but my internet speed is a cringe worthy ~300kbp/s).At least @zlaja84 knows about the moto e chipset and similarities with l70 and I belive that he has tried some of that stuff... I mean, moto e has worked perfect for me to port some roms (coming soon) to l70 because of chipset, but Im not sure if it works the same way for the code.
Oh... Ok but i have to report some bugs that probably few people noticed:I found some bugs that weren't repoted yet:
1. Smart Lock with Bluetooth Devices/Location isn't working... Only the Face Unlock is working...
2. On Google Maps, I can't get my location.. It just says: 'Waiting for location...', and nothing happens..
Oh, you forgot that if we put the phone on Power Saving Mode, the screen is getting turned off until we put it back to Balanced by connecting the Charger, and the Mobile Data is not working without net.sh script, bla, bla, blaOh... Ok but i have to report some bugs that probably few people noticed:
1. NFC at d320n is not working
2. Ril for D325 (dual sim) is not working
3. Front/back camera on ms323 isn't working
Hope this helps because 200 people totally did not reported it in this 54 pages![]()
Well, that power saving isn't bug... I think... On oneplus one when I put it in power saver it disables animations (makes it look that flagship is lagging) soo not really sure did they make it like that just for these devices or it is really a bug...Oh, you forgot that if we put the phone on Power Saving Mode, the screen is getting turned off until we put it back to Balanced by connecting the Charger, and the Mobile Data is not working without net.sh script, bla, bla, bla)
Why you reporting this bugs? -_-Oh... Ok but i have to report some bugs that probably few people noticed:
Edit: 4. Big news!! we have discovered that mobile data isn't working!
Because 200 people totally didn't reported it ;DWhy you reporting this bugs? -_-
You got meBecause 200 people totally didn't reported it ;D
And totally not trolling... xD
Fix for mobile data on LG L70
1. Download the SH File: http://d-h.st/dPZk. Then, put it in /system and change its permissions to 744.
2. Download SManager, on first run, give it superuser permissions. Find the file in /system and tap on it. Then, click su and net (see screenshot).
3. Disable WiFi, enable data and click run.
Belgians! ;DL70 community is growing at a very good rate. We are all around the world!!! We have Americans, Russians, Brazilian's, Puerto Ricans, Cubans, etc. I'm proud of this ^.^ Keep Up The Work![]()
You write question and answer in same time. Best oneflashed last night cm-12-20150224-UNOFFICIAL-w5.zip >Unfortunately System UI has Stopped and data doesnt work. what should we do? flash an older version?
Just wait 10-20 seconds, and the Mobile Data should activate...Help, I'm getting invalid ip adress error. I'm root and trying with wifi turned off, don't know whats wrong. Thanks
Does anyone know what's new in the newest update?
I'm LG L70 Dual User!Very little free time at last times. I will try to look at the weekend that with systemui.
I can disable auto OTA builds if you don't want to be on the cutting edge of progress.
For my L70 Dual CM12 is unusable without ril.
I'm 99% sure that systemui error is cm12 related, as I get it also on my private build of pacLP from a few days ago (pac is heavily based on cm12, for those who don't know) while on slimLP I don't have it. Just wanted to let you knowVery little free time at last times. I will try to look at the weekend that with systemui.
