ms323 users show logcat if systemui crash on 20150302
About 15 minutes.How much time did it take to actually boot for the first time, because I'm still waiting.. I has been an hour and 15 minutes.
That means this cannot be a good sign.About 15 minutes.
after a new installation data not work before applying fix
somehow help you try to fix data?, script not work on last build..
Read the forums man -__-Hello i am a newbie in this forum and with the roms cwm and everything but i managed to install the rom and everything is working ok except mobile data connection (no internet access on data) i did try the net.sh and with SManager and still i cant use data connection , my phone : LG L70 D320N ca someone help me ?
Hi. I am a newbie hereit seems that is working with
1. Download the SH File: http://d-h.st/dPZk. Then, put it in /system and change its permissions to 777.
2. Download SManager and find the file in /system and tap on it. Then, click su and net.
3. Disable WiFi, enable data and click run.
busy box installed
so thank you
Ill help you, PM meI do not have a backup, make sure and not working my lg flash tool, but I need to get back to my stock ROM, acrecería if you help me with that
Read this thread. You dont need to change permissions...Hi. I am a newbie here.
Can somebody tell me how can change permission? Thanks guys. Great work.
It is impossible to make a custom recovery without the device...I have the LG Realm which is also called the LS620. It seems to be identical to the L70 except for the Realm is made for boost mobile. I do not care if the cell portion of the phone works, i just use it like an iPod. I was wondering if anyone knows if this ROM would work for my device, I know that you cannot make any promises, but I would like your opinion. The Realm has no development done for it unfortunately, so i was also wondering if the custom recovery for the L70 or a similar phone would work on the Realm. Any help that you can offer is greatly depreciated, thank you.
I assumed that, but since the both the L70 and Ls620 are basically the same device (only difference I can tell is the carrier), I thought that the custom recovery for the L70 might work for me. Is there any chance or am I completely wrong?It is impossible to make a custom recovery without the device...
LG Realm - Qualcomm Snapdragon 200 MSM8610I assumed that, but since the both the L70 and Ls620 are basically the same device (only difference I can tell is the carrier), I thought that the custom recovery for the L70 might work for me. Is there any chance or am I completely wrong?
Yeah, did not notice that... that is unfortunate.LG Realm - Qualcomm Snapdragon 200 MSM8610
Lg L70 - Qualcomm Snapdragon 200 MSM8210
I assume that this explains everything...
