Root Unofficial CyanogenMod 12 for LG L70 D320 D320n D325
Status
Not open for further replies.
CM12 DualSim RIL Coming soon...
Hello guys! :)
cm-12-20150304-UNOFFICIAL-w5.zip installed on my L70D320N and everything works fine, except the GPS (cannot locate on maps) and the screen is flickering when receiving calls during screen lock. Is there any fix for it? Or i have to try with cm-12-20150306-UNOFFICIAL-w3ds.zip ?
Fix for mobile data on LG L70
1. Download the SH File: http://d-h.st/dPZk. Then, put it in /system and change its permissions to 744.
2. Download SManager, on first run, give it superuser permissions. Find the file in /system and tap on it. Then, click su and net (see screenshot).
3. Disable WiFi, enable data and click run.
"# /system/bin/sh/ system/net.sh
The IP adress isn't valid"
Status
