Fix it with the "net sh" file located in the OP(page 1)Anyone knows what this exclamation mark shows? What does it mean?
Oh, I saw that link just nowGuessing that's the OnePlusOne. But people ALWAYS and I mean ALWAYS leave out the SD to Internal .zip that's been roaming around this forum forever now. I mean look at mines!
http://androidforums.com/threads/make-sd-card-as-internal-memory.887942/#post-6836700
You don't need net.sh for the latest build, I understood...Fix it with the "net sh" file located in the OP(page 1)
The latest build has it fixed but its system ui error renders it useless. So we are forced to use older version that doesn't have data fixedOh, I saw that link just now)
Thank you very much, I think it will help me!
Large files still can't be transferred from pc to phone,anyway it's excellent rom.
use the net.sh file man.NO PUEDO ACTIVAR MIS DATOS TENGO EL LG L70 D320
AYUDENME!!! :/
For now xposed is not stable for Lollipop. Don't use itIn xposed lollipop thread there's 3 files.. I have download of them.. And flash the zip file by cwm.. Then reboot the system and android upgrading for so long.. After flash, I didn't find the xposed and my some apps has gone! I don't know what's happening.. Please give me a full toturial.. And last, what's the .jar file for
... WHY DID NO ONE TELL *ME* NOT TO USE IT???For now xposed is not stable for Lollipop. Don't use it![]()
Interestingly....LOGCAT LOGCAT LOGCAT LOGCAT LOGCAT LOGCAT LOGCAT @vm03 ms323
now fix systemUI
https://mega.co.nz/#!jM0kVTBB!5Bj1fWsN6nOQFP8DEa3rg3mG-VojcsEtdlCu3EXLahk
If that isn't enough I'll go back to a FCing update and provide a larger one. Backups are awesome![]()
mount
ls -l /firmware/image/
Its crashing on every build after version 2/19.Interestingly....
Can you show (after su)
Code:mount ls -l /firmware/image/
And I don't understand... On all of ms323 system.ui crash on latest builds or some???
This also confuses me. Maybe theres's something with cm12, as people report me FC's only on PAC which is cm12 based, while no one reported on Slim (AOSP base). But it really confuses me that only some ms323 have problems, while others not.Interestingly....
Not true I'm running latest build on ms323 with no crashesIts crashing on every build after version 2/19.
From logcat I see the reason:This also confuses me. Maybe theres's something with cm12, as people report me FC's only on PAC which is cm12 based, while no one reported on Slim (AOSP base). But it really confuses me that only some ms323 have problems, while others not.
Maybe problem lies that someone had 10b, and others 10c firmware prior custom roms? IDK, I'm really confused, just throwing ideas here.
E/QSEECOMAPI: ( 1564): Error::Cannot open the file /firmware/image/keymaste.mdt
Did you have 10b or 10c before installing any of custom roms?Not true I'm running latest build on ms323 with no crashes
Is that fixable?From logcat I see the reason:
/firmware/ it mounted modem partitionCode:E/QSEECOMAPI: ( 1564): Error::Cannot open the file /firmware/image/keymaste.mdt
