What's new in newly updated one?I did not know when I changed the animation that CM changed button...
Working NFC + april foolsWhat's new in newly updated one?
Because it's for older version of rom...If you use the zip to remove the emulated internal memory goes down the NFC
Most likely, nfc service not like memory changes in framework. Or nfc service very tied to framework version.If you use the zip to remove the emulated internal memory goes down the NFC
The company that made One (OnePlus) always delay release of their rom... There is a joke coming Soon™ xD
Is working well.Google Now Not Working
install correct gappsGoogle Now Not Working
Its already rooted... Just enable developer options and then root access -> apps and adbi use this for rooting
http://download.chainfire.eu/695/SuperSU/UPDATE-SuperSU-v2.45.zip
Battery saver mode isn't a cyanogenmod problem... It works like a charm on my One...For newbies:
1. Battry saver mod bug is bug in Cyanogenmod. We must wait for fix from CM team, not from VM03 i think.
2. ROM is rooted, flash supersu or enable in developers settings.
3. Bootanimations is not ugly, is only april fool from vm03 [emoji14]
4. Not have official lollipop theme? LoL? (Ah yes, lollipop rom have a kitkat theme...)
Cyanogenmod 12 for LG L70 D320 D320n D325
View attachment 79850 View attachment 79851 View attachment 79852
View attachment 79853 View attachment 79854 View attachment 79855
View attachment 79856 View attachment 79857 View attachment 79858
My port of CyanogenMod 12.0 for LG l70 D320 D320n D325. It is unofficial and unsupported by the CyanogenMod team.
Absolutely NO WARRANTY! You can brick and destroy you device!
For advanced users only. Please, no stupid questions.
For install need unlocked bootloader and CWM or TWRP recovery.
For correct working RIL (Sim detection) and keys you need correct (for you variant of L70) bootloader (aboot.bin).
Working:
Not working:
- Display
- touchscreen and multituch
- Hardware 3D rendring
- RIL - SMS, MMS, calls...
- Mobile data
- WiFi
- GPS
- Bluetooth
- WiFi, Bluetooth, USB tethering
- Audio - speaker, headphone, mic, routing, voip calls, etc
- Camera - photo and video
- SD card
- FM radio
- Hardware video decoding and encoding
- Sensors
- Double tap to wake
- SmartCover
Download
- NFC for D320n
- Rear camera for D325f8 and MS323
- Any others for unknown for me versions and revisions.
Since 20150208 see new builds on http://vasy.ru/CyanogenModOTA/builds/full/
(w5 for L70, w3ds for L40)
Gapps http://d-h.st/users/TKruzze/?fld_id=44392#filescm-12-20150131-UNOFFICIAL-w5.zip https://yadi.sk/d/QMPZZKBYePW7V md5: a57f787ff557856491b31ee6f0c8d73f
cm-12-20150125-UNOFFICIAL-w5.zip https://yadi.sk/d/X-zQjIYVeDnaW md5: 5f2bf656ff2d3b9bdb4675d0aa0dccea
cm-12-20150119-UNOFFICIAL-w5.zip https://yadi.sk/d/poRumQPXe6EUP md5: e79e26dad9f53aae0b5a8c7cd57bccb9
cm-12-20150117-UNOFFICIAL-w5.zip https://yadi.sk/d/lsnmUIs2e3y7a md5: 7080a2d5faf2a1551103ecd854809254
cm-12-20150110-UNOFFICIAL-w5.zip https://yadi.sk/d/dM7DnxOIdvWVXmd5: 6bb5fd368df7b1c53070a13b4bf9c682
cm-12-20150106-UNOFFICIAL-w5.zip https://yadi.sk/d/Mt0VGt3RdpJCY md5: abce7cee8b3a04051231603b2fa723c9
cm-12-20150105-UNOFFICIAL-w5.zip https://yadi.sk/d/IdZZrSyedoX37 md5: d375e7503b15559fab8d38eefd068fa1
TWRP v2.8.6.0 twrp_w5_20150328.img
cyanogen_recovery_w5_20150207.img https://yadi.sk/d/sxiBlfNfeZHaH unstable, no backup, wipe if enter by keys, slow bootup...
For full working OTA you need TWRP v 2.8.6.0 or cyanogen recovery. If you use CWM or old TWRP you can download OTA and install it manually from recovery.
Source
Kernel https://github.com/vm03/android_kernel_lge_msm8610
Device https://github.com/vm03/android_device_lge_w5
https://github.com/vm03/android_device_lge_msm8610-common
Proprietary https://github.com/vm03/proprietary_vendor_lge_msm8610
- Copy zip's to SD
- Enter to recovery
- wipe data
- install zip from external_sd cm-12<...>.zip
- install zip from external_sd gapps
- reboot
Donate
Hello, I am new here and installed this ROM on my LG-325f8. Almost everything worked. Only the home button and the network does not work. I can not make calls and or receive. One could make a suggestion. Thank you so very much.Changelog
2015-03-28
2015-03-25
- Fix performance profiles
- enable KSM
2015-03-18
- New GPS HAL lib's
2015-03-14
- Fixed Bluetooth mac address
- Reduced minimal system size for resized partitions
2015-03-07
- New Adreno libs (userspace 3D drivers) - up to 20% faster 3D
- Fix in audiorouting (mic and headpnones)
2015-02-15
- Fixed RIL (Sim detection) on DualSim D325
- Fixed Mobile Data
2015-02-08
- Better implementation tap2wake. No problem with drop calls if enabled end call by power button option.
2015-01-31
- Implemented OTA updates. Starting with this version, here I will only write about major device specific changes.
2015-01-25
- CM updates, no device spcific
2015-01-19
2015-01-17
- Fix SmartCover and Magnetometer (compass)
- Fix key on ms323, thanks to @crutchcorn
2015-01-10
- No device spcific, only CM updates
2015-01-06
- More fix camera freeze
2015-01-05
- Fix camera freeze
- Fix keys for D320👎
- Add Display Color Calibration
- Add NFC firmware
- First universal
ALLL USER????@vm03 plz can disable the internal storage for latest update? All L70 d325 users want
Speak* for yourselfALLL USER????
Vote for yourself.
Cuz they lazyWhy such a problem if there is Xposed with XInternalSD and also repartition tool?
um not lazy. I used folder mount app for mount games from sd card. But i cant install big games through playstore. thats why i thought internal disabler will be usefull for others and xposed fromework is not supporting for this rom.Cuz they lazy
Lol, just kidding xD. Only game that had more than one GB is asphalt 8... And I used some old Chinese techniques... xDum not lazy. I used folder mount app for mount games from sd card. But i cant install big games through playstore. thats why i thought internal disabler will be usefull for others and xposed fromework is not supporting for this rom.
