Root Unofficial CyanogenMod 12 for LG L70 D320 D320n D325
Status
Not open for further replies.
I have upgraded the previous build to this version and i have noticed some bugs on d320. Home key don't wake device up, and the menu key operates like back button.
Thanks for hard work though.
You are using CWM recovery right ? if yes then you have to install TWRP. just download image, put it on SD, download app called Flashify and flash recovery with it :) then reinstall Cyanogenmod and everything shoulld be fine :)
I bricked my phone :D how can I get to recovery ? :D I can go to download mode and I can also do a factory reset but I just want to go to recovery cuz I have backuped it via TWRP :) thanks for answer :)
PROBLEM FIXED :D
I registered here only because I wanted to personally thank VM03 for providing quality CM port for LG L70!
Big up my friend, I use it on my D320n and so far it has been terrific. Please keep on providing bugfixes and updates for it.
I see you constantly change versions with better implementations, so I just wanted to make a minor suggestion if you can try to improve the camera, since with the original KitKat ROM, somehow the camera quality was MUCH better in every way. Other than that, I have no other issues.
Thanks for your time.
All there is is download and download now, i keep getting the exe, and i openedthe exe and declined everything but what i want and i get nothing
Ok i got into twrp by holding volume ⬇ and power, then when the lg logo appearse i released and held the power button again then clicked yes to factory reset but it took me to twrp instead :)
The gapps, the last file on the list after you click the first link, and i installed the cm zip and im just atthe boot logo for cm.. I had to have the 2nd file flashed at the same time didnt i, and is there a button combo to get into twrp
Just click on right Download button :P
Status
