Its the EMUI 3.1 CM12.1how awesome is this theme.
could you please give me the link ?????
F9 ???? Small system partition, resize for cm13.My device D325f9, is it take a long time to flash the rom? its stuck at Patching system image unconditionally and the progress bar not moving
Cool! Will do that and report back. Thanks.there is not problem in cm12.1 with the latest update. maybe you have to re-calibrate the battery
u have to unlock the boot loader firstis fastboot and download mode the same because when i do the vol up + put usb in and all i get is download mode and no access to fastboot according to minimal adb and fastboot
Edit: while holding vol down + puting usb in makes the phone screen turn blue and on the pc drive D: shows up and inside only 2 folders "image" and "verinfo"
use an app called aparted, to partition the sd card. it worked for me. first delete all the partions and then create a new ext4 partion.How you fix for SDCard problem? Mine is gone. I use Mini Partition Wizard for repartition sdcard (fat32-ext4-swap), but even TWRP don't recognize it...
What tools i can use to repartition my system? i use http://androidforums.com/threads/expansion-memory-applications-installed-in-l70.946814/F9 ???? Small system partition, resize for cm13.
i suggest to give up on cm13 for now. and use SLim Rom.I have any problems with the last actualization cm 13, I feel so lost the root mode, the application, file management it does not work and the micro sd not recognized or mobil reboot, mi cellphone is the lg l70 ms323, please guys help me
use Aparted. its an app on google play.What tools i can use to reparition my system? i use http://androidforums.com/threads/expansion-memory-applications-installed-in-l70.946814/
before. but there is no allocation for cm13 in that tools
you're a beta tester?@vm03
After few days of testing latest release, i can tell it's pretty stable, and good for everyday use, there are some minor bugs, but it's still an early builds, so overall it's awesome
Thanks for your hard work, looking forward for a new build. I'm a "Flashoholic"![]()
Okay, my sdcard has 2 partitionuse Aparted. its an app on google play.
if you are testing something VM03@Mg977 What do you mean by beta tester? I use builds as everybody else...
@yiez176 Not SD Card, internal memory
use this: http://androidforums.com/threads/disable-internal-sd-emulation-for-android-l-and-partition-table-tool-for-lg-l70-l65.921136/
Yes, i'm a VIP ELITE cm13 beta tester for vm03, i'm getting payed every month over 1 million dollars for testing purposes.....if you are testing something VM03
I think my question is not at all offensive to you, it shows how little education you have, if you have more or charged for it is not you can perhaps save the morrow he may be required for that so stupid character that hasYes, i'm a VIP ELITE cm13 beta tester for vm03, i'm getting payed every month over 1 million dollars for testing purposes.....
Hi, can you explain me how to make it, I don't care with frontal camera but if rear camera works for me, I'll be very happy so, if you wan can be in portuguese....in d325f8 is so replacing the native camera by the play store she works , since the front is closing alone
