Root Unofficial CyanogenMod 13.0 for LG L70 D320 D320n D325 MS323
Hey guys, am I the only one stuck on the "patching system image unconditionally..." forever? I'm on the MS323 and using TWRP
EDIT: PhilZ too! D: And on both of my phones this was an issue (and now one of them isn't useable, but that was my stupid fault)
Small system partition size. Need to resized it >1 Gbyte.
Till now everything went smooth and tbh this last update seems to be stable and smoother than any other custom rom i installed...
Thank you vm03 for spending your free time developing os for our beloved lg!
some photo camera in the d325f8 cm13 , HDR mode does not work and look closely there are some white stripes on the picture.
After adopted storage I cannot see the SD card in MTP or mass storage mode. I did something wrong?
EDIT 1:***It works in Windows 10, perhaps is the driver in Windows 7
EDIT2: You can FIX it starting CMD as "run as admin" and then list all installed drivers in the Windows 7 driver store via:
pnputil -e
if this caused a longer list you can pipe that into a file via:
pnputil -e > C:\driverexport.txt
Find all your old drivers (Driver package provider : LG Electronics, Inc. Class : Universal Serial Bus controllers <<< should look like this <<<if you remove all your lg drivers it should fix the blue screen) To fix the storage of sd card just remove all old google and windows universal serial bus controllers.
If you have found now the driver you need to remove use the following command:
pnputil.exe -d OemNUMBER.inf
replace NUMBER with your number from your example. You might try to use -F to force the uninstallation. After all just do a reboot of your computer and your drivers are completely removed.
Can someone integrate Google Apps in ROM's Installer, please ? I really need this, because I really want to use this ROM, and when I try to Install Google Apps, it tells me that I don't have enough memory... It dosen't matter what Google Apps 6.0 version I use... And I make a complete Advanced Wipe using TWRP 2.8.7.0... If I Install the original ROM (.zip version), I find in WiFi Settings all the connections from this year... Even if I make a full Advanced Wipe, a partition is not being Wiped, the one that contains WiFi Networks, and when I try to Install Google Apps, that partition stops the Install, because Google Apps checks the Memory before being installed... If I can pass that check, I can Install Google Apps... And ROM's installer don't have that check...
Thanks! :)
i have another problem in the L40 model which is it doesn't show me the boot animation and it take lots of time to boot and sometimes i have to press the power button 4-5 times to bring up the phone.
1 times power button, after full boot. I will try to fix it. But for L40 we have dedicated tread. :)
@vm03 One bug,FM Radio volume control is not working, sound is always at maximum....
Thanks for new build :)
Edit: Two more bugs
1.Can't turn off "Vibrate on touch" in settings (Back and Menu keys still vibrating)
2.Offline mode charging not working at all
