Root Unofficial CyanogenMod 13.0 for LG L70 D320 D320n D325 MS323
I will try this ROM when the GPS and Camera starts working. As once before my friend has damaged my old HTC Vivid 4G's camera. As the Rom downloaded was in early stages and as in this Rom the camera wasn't working and while my friend was using the flashlight (in smartphone of course) he accidentally(as he says) opened the camera in homescreen and that did a major hardware damage. And even after replacing the camera/flashlight modules it did not work ever again. I guessed it was a motherboard issue afterwards and left the phone alone. As buying a new phone would be much better than replacing the motherboard. The main point I am getting to at here is that maybe waiting for a more stable (Edit: build of this) ROM would be much better at this point. Well of course you can disable the camera app in apps setting. But still after my past incident, I would not like taking any chances. Anyways thanks @vm03 for this awesome edition to our L70.
So can we expect weekly updates vm03
If I can recall right we will be getting unexpected updates/releases of this ROM until it gets more stable like the other CM 12 and CM 12.1 ROM. And then we will get weekly builds. Correct me if I am wrong. But I am saying this from past experience with upgrading LG L70 and other (DX, Vivid, Xperia Z, HTC One) smartphones from time to time.
Why my phone D325 dual, no sim detection, laucher crash, Settings crash, dont install app, .... don't feel anything
Sad !!
It was already on the OP. RIL/Sim detection doesn't work on dual sim devices. Just like when CM12 is 1st released, RIL is currently working only on single sim L70s.
Because we do not look at what works and what does not work, so we do not fill the thread of repetitive questions
I would set guidelines to test the different compilations and if we find a fault somehow mention it such #bug
Anyone here tried to flash this on D325? Cause I downloaded the ROM twice but still installation fails.
@wm03 it says "system partition has unexpected contents after ota update". It's booting but stuck on cm logo.
I use d325 and used cwm , it works
it does not support Portuguese - Brazil , even when it starts in English when I try to change the language in the settings it loops
OK I got it working but with the gapps in the op I kept getting unfortunately play service_ has stopped every few seconds then I opened the file manager and it said I had no root access so I flashed supersu and the had some bootloops for breakfast lol that cm boot animation gets old after awhile
italian language bootloop and at the startup "google play services has stopped"
cyanogenmod hate me. this morning i power up my l70 with cm 12.1 and it lagging. i reeboted and at the startup all formatted. bad day :(
you seem well Telegram create a channel to warn of new facilities or other issues LG L70
When a zip climb message is written and all this in the channel can test the rom, it would be a help VM03
Cyanogenmod 13.0 for LG L70 D320 D320n D325 MS323
My port of CyanogenMod 13.0 for LG l70 D320 D320n D325. It is unofficial and unsupported by the CyanogenMod team.
View attachment 95931 View attachment 95932 View attachment 95933
View attachment 95935 View attachment 95936 View attachment 95937
View attachment 95939 View attachment 95940 View attachment 95941
Absolutely NO WARRANTY! You can brick and destroy you device!
For advanced users only. Please, no stupid questions.
For install need unlocked bootloader and TWRP (20140403 or later) recovery.
For correct working RIL (Sim detection) and keys you need correct (for you variant of L70) bootloader (aboot.bin).
Working:
  • Display
  • touchscreen and multituch
  • Hardware 3D rendring
  • RIL - SMS, MMS, calls... for single SIM devices
  • Mobile data
  • WiFi
  • Bluetooth
  • WiFi, Bluetooth, USB tethering
  • Audio - speaker, headphone, mic, routing, voip calls, etc
  • SD card
  • Hardware video decoding and encoding
  • Sensors
Not working:
  • RIL - SMS, MMS, calls... for dual SIM devices
  • GPS
  • FM radio
  • Camera - photo and video
  • Double tap to wake
  • SmartCover
  • NFC for D320n?
  • Rear camera for D325f8
  • Any others for unknown for me versions and revisions.
Download
cm-13-20151025-UNOFFICIAL-w5.zip
benzo-gapps-M-20151011-signed-chroma-r3.zip
TWRP >= v2.8.6.0
Source
Kernel https://github.com/vm03/android_kernel_lge_msm8610
Device https://github.com/vm03/android_device_lge_w5
https://github.com/vm03/android_device_lge_msm8610-common
Proprietary https://github.com/vm03/proprietary_vendor_lge_msm8610
  1. Copy zip's to SD
  2. Enter to recovery
  3. wipe data
  4. install zip from external_sd cm-12.<...>.zip
  5. install zip from external_sd gapps
  6. reboot
Donate
