Root Unofficial CyanogenMod 13.0 for LG L70 D320 D320n D325 MS323
I had a bit of play store troubles but after a reboot or two they were gone. I've been running this ROM since two hours after release. Stable for now onle one force close of the system ui it was when I change the volume to vibrate. But then it was okay. Idk I love it though, thanks again vm03
once used as internal memory sd not recognize the phone I wanted to cm12.1 and nothing sd and the probe is not damaged and works on my tablet I can do
and even returned to stock and remains the same
Format your SD from your tablet
Whatsapp doesn't work correctly. I can't download the photos. I think it's because of the changes on sd card. If you are using l70 as a primary phone i do not recommend CM13 yet. Also adoptable storage doesn't work properly i have a class 10 ultra speed 1 sd card but adoptable storage thing is not working correctly. The apps which are on sd card are laggy and always crashes.
It's working like a charm.
New update removes Google Now On Tap? Everytime I enable it, the Google App stops working. I held down the menu key, nothing happens. I enabled soft buttons, held down the home button, nothing happened. Is there a fix for this? Some function where also removed: SIM Card Detection (Worked on First Build), and The Voice Search from the Lockscreen, (It's back to the call logo), I feel like I'm using Lollipop again. Does anyone else have these problems or am I the only on in this thread using the LG Optimus L70 (MS323).
@Maslovicz as is its sd class mine is 10 mi me past, passing many apps to sd internal memory as any file becomes corrupted and you have to reconfigure all sd again, hence the problem that I had to up the I describe fortunately, with the help of Othello and solved it
#bug Another problem to put the USB Debugging enabled if the PC is plugged into the PC skips a blue screen and reboot the pc
Someone talked about that BSOD already/somewhere.. You can fix it by installing latest Google USB Drivers, instead of LGE USB Drivers.. :) http://developer.android.com/sdk/win-usb.html :)
Great job so far!!!! I have found one issue but it may only be my device. When watching a YouTube video or any others while using a bluetooth headset, the video only plays for a second and then glitches. Bit if the headset it off the video plays perfectly.
Thanks for new Build @vm03 , I tried it yesterday on my LG L70 D320n. And it worked fabulously, In case someone had problem mounting the SD Card as Internal Storage I am writing this steps for you(And this does not need any ROOT from build in or SUPERSU.). First of all I have a Samsung EVO Class 10 with UHS-1, And I would recommend a similar SD Card to anyone wanting to play high capacity games(I played Mortal Combat X yesterday without any lag about 5 matches in one go, Marshmallow Rocks ;)). And secondly don't forget to upgrade your recovery to the newest "TWRP 2.8.7.0" before proceeding to next steps(If you haven't already).
Step 1 : Format your SD Card in your Computer at 8192 bytes "Allocation unit size" and only store CM13 and Gapps on it and plug it in your Smart Phone.
Step 2: (For those with turn off phones)Hold both power button and volume down and as soon as you see the LG Logo release and press the same buttons again to enter factory reset mode then choose "YES" by scrolling with your volume buttons a few times.
Step 3: I highly recommend starting totally fresh by wiping all data, cache, dalvik cache, system and internal storage(make backup before) EXCEPT "SD CARD".
Step 4: Install both CM13 and GAPPS as normally. And reboot your phone. It will take a some time for first reboot so please have some Patience and don't restart your Smart Phone.
Step 5: If you have followed all steps correctly you should see your SD Card ready to be formatted(in the Statusbar - Notification Drop down bar) to Internal SD after completing the "Setup Wizard". Choose the right options in the given window as everything is self explanatory.
The only problem I faced and I know for sure you will face as well is that. If you turn off your phone at night like me to save yourself from a bit of Radiation o_O and also give some resting time to your phone lol ;). The next day before restarting your phone you have to remove SD Card before. And put the SD Card after the OS is properly loaded. And that's how you will see your Apps again.(If you restart your phone immediately you won't have to do this.)
Hope @vm03 , Fixes this ^ soon and also the double tap to wake feature, which is the only thing I miss in this ROM. Thanks once again @vm03 for this awesome ROM and all the best on fixing the leftover nonworking issues in this ROM, we really appreciate it. Cheers.
Yeah I am also waiting for @zlaja84 , But I think he's waiting for the source code from the AOSP, Nameless Rom and other Dev's to start building further custom ROM's for our L70's as Android 6.0 Marshmallow is quite new at the moment. Cheers and thanks in advance to all our Awesome Dev's out there including @zlaja84 , @vm03 and others on this forum.
What he said. I cannot go ahead of ROMs :)
For example, Nameless has only ~10 6.0 patches so far, Slim is yet to fix build errors and some other stuff, AOSP source I'll be using is in preparation, and I'm planning to work very, very closely with team which maintains it. When they (ROMs) are ready for building, I'll give my best to port them. Plus, there's no need to hurry, even CM is in early stages.
In settings, I have not found APN, where are ?
Step(Image) 1 : Select "Data Usage" in Settings.
Step(Image) 2 : Select "Cellular Networks" in Data Usage.
Step(Image) 3 : Select "Access Point Names" in Cellular Data.
Step(Image) 4 : And finally click the + on top right or edit the given APN's to your desire.
Cheers hope this helps.
Just tried enabling Navbar on this ROM and it totally works. here are the steps:
"From the shell, be it adb, or a Terminal app, or Tasker's "Run Shell" action, enter the following command with root privileges "su" :
settings put secure dev_force_show_navbar 1".
Source and original credits to Android Enthusiasts Stack Exchange.
Edit : Don't try "Buttons and Layout" or "Navigation ring targets" in Buttons settings as its not yet optimized for our Custom Rom and it will give you a system UI force close when you do so.
