Root Unofficial CyanogenMod 13.0 for LG L70 D320 D320n D325 MS323
I have the LG L70 “Black” I have this ROM awesome I put this on my friends phone he has LG L70 MS323 “White” my data works and he's doesn't can anyone help?
Yes, it does
I formated even the /system with f2fs, and it is working.It does take a little bit longer to boot, but eventually it does, and it is all ok, so /system, /data and /cache with f2fs.
Edit: correction, I did format the /system with f2fs, but when I installed the system, the script? format it to ext4, so /cache and /userdata are on f2fs, and /system on ext4
Can someone explain me what f2fs do?And how i can use it?
Hi,
f2fs as far as I know, it is a fyle system developed by Samsung, and it supposed to give better speeds, better compression, and so on; it will be at some point a replacement for ext4, I guess....
[QUOTE="Codoci, post: 7139521, member: 1802arey other updates or just the dual sim utilization ?[/QUOTE]
Also advanced reboot. But for me the gapps (google play service) it is not working :(
[QUOTE="MarshLg70, post: 7139111, member: 189963]So i can format sd card with this type of file system, or use it with system memory with twrp?Some manual maybe?[/QUOTE]
Honestly? I did not tried it on a SD card, just as filesystem, particularly for /cache and /userdata, so I do not; you can try and share the result with us :)
just ready to try this, but one question..i have repartitioned my internal before (2.6gb now), do i have to revert the partition table to stock befor flash this? or just do the flash without revert it?
I also have a custom partition scheme, you do not need to revert to the original partitions, just install it, but after a complete wipe (/data, /cache, /dalvik.....) if you had a different rom before, even for cm12.
It is just me, or it happens to somebody else?
I do not have the right to save to the external sd card from apps such as UC Browser, snap, stock camera. I can use the external sd card normally for other operations, but not from the ones I mentioned.
If someone can help me with the following:
I did a clean install (wipe all), but I did not installed the gapps; all went smooth, the apps runs ok, waze, maps, super backup; I installed benzo-gapps and the apps ( waze, maps) keeps crashing, I can not coonect to my google play account.
What it is to be done? It is just me?
Edit: I installed opengapps (pico), and it works! Everything works, no crash at all!
You have to flash gapps for sure
How can I fix my SDCard? After cm13, trwp and cm12.1 doesnt recognize the sdcard even on FAT32!!
But on Windows, the SDCard works great
Did I lost my SDCard?
