Root Unofficial CyanogenMod 13.0 for LG L70 D320 D320n D325 MS323
How can I fix my SDCard? After cm13, trwp and cm12.1 doesnt recognize the sdcard even on FAT32!!
But on Windows, the SDCard works great
Did I lost my SDCard?
Format your SD card as ext4 on twrp
Wipe-Advanced Wipe-Sd Card-Liitle box above wipe forgot name- Ext4- confirme then twro should recognize
I really appreciate your help, but it doesnt work too. TWRP doesnt recognize the SDCard so cant format.
@vmo3 is it just me or mobile data isnt working? Cant seem to make it work even with the correct APNs. I went back to cm12.1 to try and its working fine, but not in cm13.
Another one is (though its not really an issue) battety calibration is way too off. The good thing is i have 3000% battery. LOL. Enough to power my phone for weeks without charging. XD
I just want to point out my observations about this ROM and MM. I know we can't expect much cause it's still on early stages, but still it is worth mentioning.
1. Mobile data. I got it work for a couple of seconds (but not with the usual H+, instead it indicates H), but it can't load any pages, APNs are correct so I tried to reboot, data connection never returned again. In comparison, cm12.1 can effortlessly turn on and off mobilr data. Well, i know wifi works but ISPs here charge way too much for mediocre speeds. And I'm only at home on weekends so there's no point on having my own wifi, that's why I stick to mobile data.
2. Access to external storage. Seems like the only way* to access sd cards is from the built in MM file manager (which has limited features).
* I haven't tried any othet file manager, just the stock one and didn't tried to access it from the root folder /. So you guys tell me if this works.
3. Media scanning. Music files and pictures from external storage are 'not included on media scans'. I'm guessing we have to adopt the sdcard for this. I also didn't tried any other media apps, just stock gallery and eleven. Maybe google is forcing us to adopt sdcards if we want to fullt use it.
4. GApps. I heared conplaints about gapps crashing etc. I didn't tried Benzo from the op, instead I used OpenGApps. No issues, crashes or bootloop. You can try if you want, OpenGApps can be installed on top of other gapps packages. Just do a backup to be sure.
Note: I did a clean install first before installing gapps.
Feel free to correct me if I'm wrong. Overall this ROM is still pretty good, but I can't use it as a daily driver cause I dont have any other phone lying aroud. Anyway, development is still in progress so when can expect good things to happen. :)
I would like to thank the developer for making this Rom first of all.
I get a lot of crashes from apps. At first Play Store crashed all the time. I reflashed the ROM and flashed other Gapps version. I managed to add the SD as internal storage but now i get crashes from random apps. Should i try a faster SD card or format this in ext4 format?
Also there are some minor bugs in the ROM, i can live with them and i'm sure you will fix them in time.
Please add OTA updates.
Hi. I have an Lg d320n. I try to install - cm. 13 and it stuck on cyanogenmood logo. I try to enter recovery mode (Philz recovery), but i can`t. Please i need some help. Thanks
2015-11-15
  • Odexed
  • Increased system partition
  • Upstream updates
From this build, i enabled odex and increase system partition size.Why:
  1. Fast first start
  2. Fast start after update
  3. More free space in /data for people don't like partitions resize
  4. Anyway we need increase system partition size for M.
How can I install gapps, open gapps says insufficient storage. ROM is awesome so far though. Which size do you choose?
"You must install last TWRP."
Thanks for the answer.
Can you explain me how to install TWRP, please? The only thing i can do is to enter in fastboot mode (volume up when i release the power button).
Appreciate the help.
