OTA after it will more stable. May be after start official nightly.@vm03
Is it good as a daily driver, expect those thing that aren't working?
When you gonna enable ota update?
Thanks![]()
Try other version of gapps, also be sure to use latest version of twrpok i get setup up wizard FC. how do i fix, please help.
Thanks. i got pass the setup FC. howevere root checker and Tb says i dont have root. i run towel root, i click make it rain and it just turns orange and nothing else happens.Try other version of gapps, also be sure to use latest version of twrp
PS: I use gapps PICO.
Go in settings -> about phone, tap on build number 5 times and activate developer options. Go in developer options and find root access and select apps and adbThanks. i got pass the setup FC. howevere root checker and Tb says i dont have root. i run towel root, i click make it rain and it just turns orange and nothing else happens.
thanks. alot, im ready to rock and rollGo in settings -> about phone, tap on build number 5 times and activate developer options. Go in developer options and find root access and select apps and adb
I find out that there are too many glitches, and I reverted back to the 10.11 built....my external sd card now reads 0mb. how do i fix it? the adopted storage function is responsible
ya, im about to do the sameI find out that there are too many glitches, and I reverted back to the 10.11 built....
I agree with you, this latest one is amazing for alpha, havent used adopted storage(ill wait now) however been stable accept for browser crashing on downloads and file manager not working for me by default. other than that flawless so far.There are gonna be glitches this is an alpha version port lol but if you don't use the adopted storage it's actually not bad . Link2sd is better anyway for me I get more control over it
BBQLinux have built-in Android Development Kit.. Just install it and you are ready to go!okay so which version of ubuntu do you recommend for building from source, im trying to dig into building roms and learning. i feel that it would be a great learning tool. however cannot get the build environment setup properly on ubuntu 12.04, 15.10, and trying 14.04 now. But i want to make cm12.1 and cm13.0. I followed your guide for making from source vm03 but, it results in exited do to some error syncing. That was with repo sync though. idk
Okay got that installed thanks BTW, problems though I tried to pull mkvendor.sh from lge but it says does not exist and when trying to update android SDK it says failed to create folder and files.BBQLinux have built-in Android Development Kit.. Just install it and you are ready to go!![]()
I'm not a devoolper but I don't know just saying to fix fm radio, DT to wake, and smart cover maybe must pull it from CM12.1 idk it just sound smartOTA after it will more stable. May be after start official nightly.
