Root Unofficial CyanogenMod 13.0 for LG L70 D320 D320n D325 MS323
Hello,
First of all thank you @vm03, for the work that you do for us, to enjoy a such great rom!
I do have a problem with the waze, it keeps make the system crush; I made a clean install, with all partition wiped before installing. Did it happend to somebody else, or just to me?
Edit: When I try to use snap, it does not recognize the sd card, as in attach snapshot, and yes the card was declared as external in the begining.
Im on the new build for some hours and almoust everything is working ok even the camera (not the stock) i had an online game , dosent work . fc in some settings 2 i guess , but i dont really need them VM3 keep up
Thanks
All done, now i have sd formatted as GPT, on pc I don't see phone and sd card, i have to move all my photos and music from pc to phone, what is the right process ?
You need the new lg windows drivers then you will see the lg l70 icon with MTP in My Computer/This PC. I also had this same problem and the blue screen of death(as my friends used to say) started showing up and restarting my Windows 7 laptop every time I plugged in my LG L70. And that's when I figured out it was the USB drivers.
Edit : LG drivers are same for all L70's(and other LG's) and you can download it in this link.
Same issue for me. Danicord, did u solve it?
I'm also italian...maybe it's just a crash in our country?
Well the APN's should be automatically downloaded as far as I know and I have never manually entered it in my country for the several SmartPhones I have used. But anyways try the "Sim Toolkit" built in app or your Cellular service menu(should be some Network shortcut number to see all your Network info for example my network number is: *#888#* - You need to enter this in Phone dialer (Obviously ;))), and you should find some special number over their to install the APN's automatically. Well thats if your Network company offers it. Cheers hope this helps.
Does anyone know how to fix Sim Card Detection? I'm running the latest version on this ROM and the Sim Card worked like a charm. Now, A week later, after rebooting my device, the Sim Card said "NOPE" and wont be detected anymore. Please, by all means, help me. -MS323
Hey @vm03 , I just noticed since first installed this ROM that TWRP is not working now when the SD Card is inserted as I think when I used the "Adapted Storage"(SD Card to Internal Storage) feature from Android Marshmallow it made the SD Card in different format and incompatible with TWRP. Please can you help solve this problem in TWRP. I am really in need to make a backup of my device. Thanks in Advance.
if you have another device sd clear on that device and then passes sdformater in the pc and then place it in the lg l70
Thanks but in my case i just want to open that menu to disable roaming. Simeone can tell me if it is disabled by default? Because i pay it and i don't wanna risk to burn alla my credit
Thanks for the advice, but I actually thought of this before. And the problem is that the important data I want to backup is on the same SD Card, I want to backup and that needs to be inserted at time of the backup. Cheers and thanks anyways.
Currently Adapted Storage and backup in TWRP not compatible. May be in next TWRP version...
if you have linux, you can use "photorec". in debian and ubuntu ,use this command:apt-get install testdisk. then open a terminal and type "photorec". it is simple and powerfull.
Danicord, sono anche io italiano. Volevo contattarti in privato per confrontarci su un paio di problemi che abbiamo in comune, ma temo tu abbia i messaggi bloccati. Se ti va contattami.
