Root unpartioning sd card
Hi, my mate decided to partition his sd card on his rooted hero , now it is only saying 5gb instead of 8gb, and he wants to take the partition off but for some reason he cant. He did say that the card isnt being reconised by his computer too , and he thinks he has lost all of his data too (Unless it is in the other 2gb) what is the best way if any to revert back to a unpartitioned sd card?
cheers
You should be able to format the card to one solid FAT partiton via the options menu.
Or, if he's using the latest recovery menu, that can undo the partitioning too.
Partition sdcard >> Parition SD. Then SWAP: 0, Ext: 0 for a normal sd card.
Bear in mind this will wipe the card clean.
Options >> SD & Phone Storage >> Unmount SD card >> Format SD card.
I'm pretty sure this will get rid of the apps partition. But if it doesn't work and only reformats the normal partition of the card, the recovery menu way definitely will work.
