Root Unrevoked3 - Having trouble rooting
Bing
I've searched for hours for this, so I apologize if it's answered elsewhere, I simply can not find a solution that works.
When I start up Unrevoked for the Incredible, it says to plug my phone in. I do that, making sure it says debug mode is enabled in the drop-down pane. But the unrevoked screen doesn't change!
I've tried:
- mounting as disk drive
- "charge only"
- one Windows XP PC and one Windows 7 PC
- removed PdaNet and tried those options again
Nothing gets me past that screen. I tried looking for an HTC Sync app to uninstall, or setting to disable (since it says "make sure it is NOT installed"), but I wasn't able to find anything.
Any tips?
I thought the newest Unrevoked did all that for you, but now that I know better I followed the instructions given, thank you.
That said, when I booted up my phone like normal, under device manager I see the following:
"ADB"... is that right? according the the instructions I should be seeing:
I WAS seeing the second image while I was in HBOOT mode, but when I started it up normally it gave me that ADB message, and when I try to run Unrevoked it still says "Waiting fro device".
Any tips?
I take it no one knows?
I experienced the same thing after loading the HBOOT drivers. I re-booted my phone, mounted as charger, w/USB debugging on. When I plugged it back in via usb, I kept getting the "new device" message, "do you want to d/l driver". While the phone was plugged in NOT in recover mode I loaded the driver again. Once I did this, Unrevoked recognized my device and I was Rooted in about 5 minutes.
